RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum Do you have the ability to RoadTest Power Integrations TinySwitch-5 RDK-1016?
  • Blogs
  • RoadTest Forum
  • RoadTests
  • Reviews
  • Replies 18 replies
  • Subscribers 2661 subscribers
  • Views 894 views
  • e14-pi
  • tinyswitch-5
  • power integrations
cstanton
cstanton 4 months ago
We're looking for a few members to RoadTest a product from power integrations.
Now, this is more of a 'reference design' than a 'demonstration kit', but we often receive requests from suppliers that are like this.
The product is:
26.5 W dual output isolated flyback power supply for appliances using TinySwitch-5 (TNY5073K)
Information and datasheets are available at: https://www.power.com/design-support/design-kits/rdk-1016-reference-design-kit
With details about TinySwitch-5 at: https://www.power.com/products/tinyswitch/tinyswitch-5
We would likely be looking for a RoadTester that can put it through its paces and characteristics rather than plugging it in and saying "it works". This means we may deviate from our usual RoadTest of 'sign up and you may be selected' and instead go down the path of 'ok, two or three of you are selected and we'll see if we can also provide you with some parts that you need'. (We tend to call these RoadTest Plus or Special RoadTests).
  • Gough Lui
    Gough Lui 4 months ago +3
    It's an interesting question - I selected that I have everything, but in reality, that very much depends on what is intended to be tested. I did a couple of Power Integrations RoadTests before ( RDR-928…
    michaelkellett 4 months ago +2
    In order to test this board comprehensively (rather than just use it) you need (rough guess) at least £50k worth of test gear (more if you want to measure radiated EMC).: AC power source Transient…
  • Gough Lui
    Gough Lui 4 months ago in reply to manojroy123 +2
    manojroy123 said: I usually use board with proper common mode choke filter at the primary side. It's their "feature" to reduce component count. I'd say that suggests they're controlling the switching…
  • Gough Lui
    It's their "feature" to reduce component count. I'd say that suggests they're controlling the switching waveform with respect to frequency to spread the noise out so as to (potentially) remain below limits.
    manojroy123 said:
    never seen common mode choke designed as inductor.
    Seems to be a pi-filter to limit the amount of noise injected back to the mains and smooth out the DC. That being said, as far as I can tell from their test reports, the board isn't officially agency approved, but I'd have to say that PI very likely know their stuff and the EMC pre-qualification they've done in their report shows it has a decent chance of passing conducted emissions depending which limit line is used ...
    - Gough
    michaelkellett 4 months ago in reply to Gough Lui
    Gough Lui said:
    (anyone with one of those, raise your hand?
    Raised hand
  • Gough Lui
    Gough Lui 4 months ago in reply to michaelkellett
    *stares enviously from half-way around the world*
  • robogary
    robogary 4 months ago in reply to Gough Lui
    Rofl - or inside listening to Pink Floyd on audiophile speakers.  :-)
    Jan Cumps 4 months ago in reply to robogary
    Raised hand
  • foxbat
    foxbat 4 months ago
    I'd definitely be in the 'turn it on and use it' camp, but the comments regarding environmental testing made me wonder about the viability of creating a shock / vibration test rig.  Motor and a selection of ALM cams to change the vibration or shock profiles, with a G Sensor and microcontroller to measure / characterise the vibration.  The ultimate aim would be to try and achieve something that could support some of the test profiles in a recognised standard (e.g.  MIL-STD-810)... but I might bite off more than I can chew with that last bit!!
  • hlipka
    hlipka 4 months ago in reply to manojroy123
    From the data sheet / RDK description:
    Fuse F1 isolates the circuit and provides protection from component failure. Bulk Capacitors C19 and C2 together with differential mode choke L4 forms an EMI filter that attenuates both common mode and differential mode conducted EMI. BR2 converts the AC line voltage into the DC voltage seen across bulk capacitors C19 and C2.
  • rsc
    rsc 3 months ago
    I was interested until I read the specs : 12V @ 2A, 5V @ only 0.5A
    Not enough 5V power for the project I was thinking of.
