Atmel SAMA5D3 Xplained, Add-On Boards + LCD Bundle
View table of contents ...
Atmel SAMA5D3Have you tried the new Atmel SAMA5D3 microcontrollerAtmel SAMA5D3 microcontroller yet? element14 is giving away 5 of these new boards, along with a bundle of accessory boards to help you get up and running in no time!
The Atmel SAMA5D3 Xplained MCU is a fast prototyping and low cost evaluation platform for microprocessor-based design. It comes pre-loaded with the Linux Kernel 3.10 (LTS), Linux Mainline and Yocto 1.5.1 support. Bare metal developers will also benefit from a complete C software package including many examples to get started fast. The board comes with a rich set of ready to use connectivity and storage peripherals and expansion headers for easy customization. A USB device connector can be used to power the board as well as programming and debugging it.
Product Video
The Accessories
Not only are we giving five of these units away, but we are including a bundle of all-new accessory boards to expand the unit's onboard functionality. In addition to the MCU, you'll receive:
Arduino UNO click shieldArduino UNO click shield. You'll need this to connect your board to the other items below.
Sensor Click BoardSensor Click Board. Measure humidity and temperature on the fly.
Wifi DongleWifi Dongle. Connect your board via IEEE 802.11n, IEEE 802.11b/g, WEP, WPA, or WPA2.
LCD8000LCD8000. Connect your board to the new 4.3-inch touchscreen LCD.
What will you build with your new Atmel SAMA5D3 and bundle of clickboards? Describe your project and you might win one of these fantastic product bundles.
More technical information about these products is attached below.
Good luck from all of us here at element14!
Terms & Conditions
  • Testers will be selected on the basis of quality of applications: we expect a full and complete description of why you want to test these particular products.
  • Testers are required to produce a full, comprehensive and well thought out review within 2 months of receipt of the products.
  • Failure to provide this review within the above timescale will result in the enrolee being excluded from future RoadTests.
RoadTest Reviews
Comments
