RoadTest Open Call
View table of contents ...
Has there ever been a product that you wanted to test and review but it has not been featured in another RoadTest here on the community? Now is your chance!
Submit an application to review any product of your choosing under $175 (USD) on the Newark / Farnell / element14 online stores.
The ten best applicants will receive their requested product for FREE and get to keep it in return for writing a review.
How To Apply
Click the button on the right to enroll by putting in your application. Here is an idea of what to include:
  • The product you want to review and why you have chosen it
  • The details of the test plan or review you plan on carrying out
  • A brief description of your background, general experience level, and familiarity with the technology (embedded systems / microcontrollers / programming / prototyping etc.)
A more innovative and/or thorough review of a new or overlooked product is more likely to give you a chance of being selected, as long as the ambition of your review matches up with your experience level and familiarity with the technology.
Example Product Review Possibilities
So, what kind of product could you review?
  • A single board computer (eg. Arduino Uno Q)
  • An all-in-one kit (eg. development kit, motor control kit, optical, wireless transceiver kit)
  • Bench equipment (eg. power supply, oscilloscope, soldering station)
Once you know the product you want to receive and review, what sort of review could you write?
The only limit is your imagination but here are a few examples:
  • The out-of-the-box experience of a product - Do an unboxing, power the product up, check any pre-programmed options or features, and follow the user guide.
  • Performance test - Measure accuracy and see if the product is faster/slower than specifications
  • Cybersecurity evaluation - Test for security holes and vulnerabilities
  • Test a product to destruction! - Show how a product holds up in hazardous conditions such as high temperatures or rugged environments.
Important Dates
Enrollment period: 23rd June - 30th August
Enrollment deadline: 30th August
RoadTesters Announced: 18th September
Units ship: 9th October
You begin reviewing: Upon receipt of kit
Post your review by: 60 days from receipt of kit
Look for parts to review on your local store
Terms & Conditions
RoadTest Reviews
Comments
  • We understand. It is gonna be harder than comparing test plans for the same product. Even to understand the test plan the judges needs to understand the product first.
  • Hey   , we had just over 100 entries in total and a lot of very thorough test plans! In order to make sure we do justice to everyone's applications, we are extending the judging period before we announce the ten successful applications.
    Successful applicants will now be announced Friday 18th September
    Their item(s) to test will be shipped Friday 9th October
  • This road test approach is a neat idea, being road tests have previously been driven by a specific supplier.
    Perhaps keep the current road test format, and add an annual competition called "Create me" posting a goal and a material list.
  • The terms and conditions pdf says on 4th the road testers will be announced. This along side your point of evaluating such large number of application will definitely take time.
  • If I am correct about nearly 100 entries - it would be kind of cool to see the items people put forward - that would be quite easy - you could even give a quick overview, anonymised entry using AI or similar?
    for example for me it was
    Order code: 4163984 (×2 units)
    Anonymized elevator pitch: Modifying two Raspberry Pi Global Shutter Cameras (removing a resistor and soldering a wire to an SMD trigger pad) to create a hardware-synchronized stereo camera pair using the cameras' external trigger (XTR) pin — a technique documented by the manufacturer but rarely demonstrated in practice. The synchronized rig is then calibrated for stereo depth and used to predict the real-world flight path of thrown/kicked balls, tested at both close (garden) and long (pitch) range, to produce a measured accuracy benchmark rather than a qualitative demo.
    and the AI prompt to extract that would be something like
    You are extracting structured data from a product road-test competition entry.
    From the attached entry, extract exactly two things:
    1. **Order code** — the Newark / Farnell / element14 product order code
    mentioned in the entry (usually numeric, e.g. "4163984"). Include quantity if
    stated (e.g. "×2"). If more than one distinct product/order code is listed,
    include all of them.
    2. **Anonymized elevator pitch** — a 2–4 sentence summary of the core
    idea/project being proposed, written so that it contains NO identifying
    information about the applicant. Specifically strip out:
      - Names, usernames, or handles
      - Professional background, job titles, employers, or specific
        skill/experience
      - claims ("I have X years of experience in...")
      - References to other specific road tests/projects they've personally done in
        the past (unless essential to understanding this idea's technical context —
        in which case describe it generically, e.g. "building on a related
        compute-module setup" rather than naming it)
      - Location, company, or other personally identifying details
    Keep: the product being tested, the technical approach/method, the novel or
    interesting angle, and the intended outcome/deliverable. Write it as a clean,
    self-contained description of the idea, as if evaluating it blind.
    Output in this exact format for each entry:
        Entry: [filename or entry number]
        Order code(s): [code(s) + qty]
        Elevator pitch: [anonymized 2-4 sentence summary]
    If the order code is missing or unclear, write "NOT FOUND" rather than
    guessing. Do not include any other commentary.
  • in the Important Dates above it states
    > Units ship:4th September
    so that would be this Friday - but I think I saw some place that there were near 100 entries and each may be mentioning different products so I am sure it will be soon-ish but may be a hard job deciding
  • When will we know when the winners are selected, I do not see that date.  Also, this is a gentle reminder that I kind of came up with this idea, ergo, I should be considered Innocent.
  • I’m really eager to find out who the final road testers will be! I’d absolutely love the opportunity to review DFrobot’s components by integrating them into an exploration robot and putting them to the test in a real-world project.
  • Its under 175USD on uk.farnell.com store. you should apply for the road-test. uk.farnell.com/.../2723824
  • Hi all, don't forget that applications for the RoadTest Open Call close at midnight (UK time) this Sunday 30th August so don't miss the chance to put in your application Slight smile
  • Submitted the entry. I plan to review a simple soldering station kit from Multicomp pro, which includes all the basic components that are must for electronic and IoT hobbyists/enthusiasts. The link to the soldering iron is :
    https://in.element14.com/multicomp-pro/mp740850/soldering-station-48w-240vac-eu/dp/3864373
  • Hoping for the best.
  • ROFL - I was hoping to find an inexpensive handheld spectrum analyzer, similar to the Multicomp Pro handheld scopes. I'm thinking that is still a few years away  :-)
  • I am truly excited to announce I have submitted an entry for this road test.
    My road test selection is well short of the $175 limit , I'm shamelessly hopeful that the number of selected road testers can increase, if alot of entries submitted are also relatively well under the max $$ limit.
  • LC9090LED
    You can definitely check the price evolution.
  • I'm using a Radxa Q6A to do whisper speech to text, a small llm.model and a TTS module. Its giving a quite good performance. its no good for this roadrest as its not available on Element14 group. I just thought I'll put in a word.
  • I had my doubts about this, and now I have emotions. Well, the price of the product I was looking at has slightly changed in the meantime. Bad luck. Face palm‍♂️Ok woman‍♂️
