Weller Soldering Station WT Series - Review
View table of contents ...
RoadTest: Weller Soldering Station WT Series
Author: dimiterk
Evaluation Type: Workshop Tools
What were the biggest problems encountered?: The only issue that was encountered was the lack of a set of tips for the WP90 soldering iron. The new tips feature a different design.
This road test will focus on the Weller WT1 soldering iron station I received from Element 14.
This is the 90W version with the North American power plug rated at 120W.
The photos below shows the Weller WT1 that was given for this road test.
The WT package is comprised of the:
  • Soldering iron WSP-80
  • Soldering station WT1N
  • Soldering iron holder WSR 201
Unpacking
The soldering iron station is named the WT1N rated for 90W. The version I received uses the short LT series tips. I was surprised to actually find only a single bevel edge tip came with it.
The WSR and the WPT80 come in their own separate boxes.
The soldering iron safety rest was unboxed next.
After setting up the soldering irons station ,the unit was turned on and the first thing you'll notice is the LED display,  with a well lit white background and black letters.
Unboxing the unit, shows that the soldering station is tucked well with the power cord in the bottom as well as the accompanying Weller manual.
Soldering Iron station
It's a bit tough to show this on the photo but the display has options for a thermocouple, an NFC connection as well as for a fan speed. The temperature rate of change is shown by a vertical bar on the LED.
Probably this unit does not support such options and the display is shared with higher end models.
There is a rubber holder on top of the unit that allows stacking additional units on top.
This is quite useful since it saves quite a bit of space. The unit has 4 buttons on the front panel as well a high contrast LCD display.
The first button returns to the main menu. The next two buttons (up, down ) are used for adjustment while the last button is used for selecting.
The default temperature is in Fahrenheit so for those that feel challenged in converting to Celsius you need to follow the steps below.
So to convert to Celcius, press the last button, move to the offset menu and press the up button to set the degrees in Celsius scale.
The RJ11 connector at the bottom is used in conjunction with the Zero Smog extraction system.This part is procured separately . I did not get to test this since I did not receive this equipment from Weller.
As with all soldering equipment it is suggested that the user use a fume extractor when working on these projects.
The other connector is a 3.5mm jack that is used for grounding for ESD purposes.
Soldering Iron WSP-80
The soldering iron has a temperature sensor embedded below the soldering iron tip.
Even though the soldering iron has a small mass, it heats up relatively fast. In less then 10 seconds it jumps by almost 100 deg.
The handle is quite comfortable to touch. When I turned on the unit for the first time I heard a humming/hissing sound coming from the bottom of the soldering iron. This stopped after a minute or so.
There are differing opinions on choosing between a brass wool and a sponge. It should be noted that the bras wool will affect the tips' life.
The stand and the station are separate pieces which allows for flexibility in how you can set it up. The soldering iron chord has a length of a bit less than 1m.
The LT series tips can be procured from the usual CM for around $12 CAD each. As was mentioned only one bevel edge tipcomes with he unit.
Quick tip: Using a high temperature shortens the life of the soldering tips so aim for a medium range temperature.
Iron Holder
The safety rest is quite sturdy and heavy. It comes with a metallic stand used to hold the tips that can be attached via screws.  . I ended up replacing the sponge with the brass sponge for cleaning the iron’s tip.
The safety rest for the soldering iron is called the WSR. (Weller Safety Rest). It comes equipped with a brass wool and a yellow rectangular sponge as well as a holder for the iron tips.
Personally I like the brass wool. The main disadvantage of the sponge is that wetting the tip imparts a thermal shock on the tip which requires a second or two for it to reheat again to the original temperature.
Project
After unboxing and setting it up , I decided to solder some 0.1inch male headers to a couple of MEMS microphones. This scenario represents the most common situation encountered by intermediate users.
I tested the unit on:
a) 4 MEMS microphone breakout boards
b) 32 SMD components on a custom ESP32 board I build recently
The bevel edge tip worked fine for all 0603 and even 0402 components as well as the IC's with the castellated pads.
I had to use a hot-air gun for one QFN24 package. Even a fine tip would not have worked in that case.
Comparing with the low end model I have been using so far one can notice that the better temperature stability and fast setting time of the WS1  makes the soldering joints easier and better.This basically means no cold solder joints in practice.
Final comments
All in all I like the fast heating time, the ergonomic design of the soldering iron and the sturdiness of the safety rest.
At this price point I would expect that Weller had also included a fine tip for use in soldering fine pitch components however all the components included are top-notch quality.
This is a product which is definitely recommended for the seasoned professional or for the hobbyist working in his home garage.
Pros:
  • Great temperature control
  • Fast settling time.
  • High contrast LED
  • Good ergonomic design
  • Excellent construction for stacking up units
  • Programmable parameters such as sleep time, offset ..
Cons:
  • More expensive than other models
  • Only 1 tip with the soldering iron
  • No accelerometer on the soldering iron so unit cannot tell when it's at rest. This is alleviated by the fact that the unit can be programmed to enter sleep mode so no biggie.
  • Supplemental Operating Instructions printout not included on the box
  • I'm not sure, but my interpretation is that it's probably advising against changing just the bits by dumping them out onto the sponge ...
    It seems to me, they're trying to say that in order to use the "holders", you should have a sleeve for each tip you intend to use and swap the whole sleeve + tip assembly.
    I know Metcal irons (as I have one) come supplied with a silicone pad which they say can be used to grip the collar and undo it, removing the whole assembly while hot. It seems potentially dangerous, so I usually wait until cool, but I guess it means "hot" swapping isn't entirely taboo.
    - Gough
  • I was wondering, what is the procedure for bit-change?
    There's this diagram in the user manual, but (to me) it didn't explain how to change the bit. Presumably the diagram marked "NO!" actually does need to be done, otherwise how will the bit (indicated in red) be removed from the bit-sleeve (indicated in blue)?
    Also, isn't both the bit and the bit-sleeve going to be hot? Sliding out a hot bit from a hot bit-sleeve seems not right (in case the hot bit accelerates sliding through the bit-sleeve and rolls off onto the table or lap.. unless there's some container or space to catch it?). So I'm guessing a second bit-sleeve should be purchased or supplied? So that a cold bit can be placed in a cold bit-sleeve while the hot bit cools off in the hot bit-sleeve, placed as in the "OK" diagram until it cools, and then the diagram labelled "NO!" can be used on the now-cold items?
  • You are so close to answering my question. I was unable to make it to the site today to take pictures and show the problem I am experiencing.
    Use the sponge configuration you have in this picture.
    Remove the barrel (with the tip still in the barrel) from the solder pencil and place it in the ring holder as shown in my drawing. With the barrel suspended in the ring above the sponge, does any part touch the sponge. The height from the ring to the sponge in my mismatched kit causes the tip to embed itself in the sponge. I am looking to confirm if that same condition does not exist on a unit with a Safety Rest/Pencil Iron match.
  • When I assembled it I mounted it like this as you can see above.
    Seems you either have a different version  as seen below or you have mounted the holder the opposite way.
    In either case there is no risk of touching the sponge or the brass wool so I don't see any issue. I also received an WSP80.
  • The station is at another site so I can't provide a picture. I won't get to the site for a few day so I will try the drawing first to see if I can clarify my question.
    This is a side view of the Weller Safety Rest I have assembled. The line coming out from the pencil rest is a metal ring with holes in it that the barrel and tip can fit in. The solder barrel and tip can be placed in the holder fixed to the rest. The length of the barrel and tip suspended in the holder results in the tip touching the sponge in the tray.
    I think your arrangement has the brass wool tray under the solder barrel and tip. No risk of touching. The unit can be configured to what is shown in the drawing. I use dry more than wet tip maintenance so the setup is more convenient.
    On you unit that matches the Rest with the pencil do you experience the problem I describe. I suspect my problem is because the Rest and its associated components is for a WTP90 pencil and my pencil is a WSP80.
  • yes but only buy the ones in the box
  • @Cristina Harrison
    Thank you for the suggestion. I already have a couple of models.  One thing I can mention is that the quality of the LT series tips form eBay is kind of questionable.
    Yes, the WSR box contains a pamphlet which specifies which soldering irons are compatible with each WSR series. The WSR201 is compatible with the WSP80 I received.
    I don't follow what you're asking with regards to the tip distance.
    If you look at the photo below the "Iron holder" sub-heading above it extends outwards. So it cannot touch either the sponge or the brass wool.
    The tip is a good 4-5 cm in the air and does not make any contact with anything.
    Even the non-Weller model I have (898D+) has a fully enclosed iron holder. A hot tip in default resting position contact with either the sponge or anything else is a safety hazard.
  • et al. here is my entry system and you can pick one up for less than $200 on eBay. tips can be found for $35 I have mine running through a footswitch.imageimage
  • Sorry for the anal focus on details. I did audit for a number of years and old habits are hard to drop. I'm disappointed I received a mismatch but it has provided exploration opportunities. If you had a 80's pencil and were thinking of moving to the 90's, the Safety Rest isn't compatible.
    When you remove the barrel with the tip still attached and place it in a hole in the Safety Rest does the tip touch the sponge. I assume from your description you have the brass under the barrel holder. What about the sponge if you flip the arrangement.
    A hot tip resting on the brass is not bad but a hot dip sticking in the sponge is surely going to scorch before the tip cools.
  • @sean conway
    Sorry for the confusion, we all got the same model.
    The soldering iron is the WSP80 (80W) , and the soldering iron station is the 90W WT1H. Seems like I messed up the acronyms.  I will re-edit the re-view.
    regarding your questions:
    a) The depiction of the safety rest is different from the actual image that comes with the WSP80 as you can see on the images above.  The tip (the soldering iron itself) is too short to touch the brass wool on the other side
    b) same when you place the tip horizontally on the holder. I don't understand though why do you need the tip to touch the brass wool.
    I was thinking to order the fine tip you referenced above. In the end I managed to solder all components apart from the QFN using the bevel edge tip.(all 0603, and SMD parts apart from the connectors)
    I decided not to compare it with a cheapo model that I had since this station has much more functionality. I have been using brass wool for the past 8 years or so.
    Maybe depends on my usage pattern but the fine tip won't be that fine after a year or so.
  • I suspected as such.
    Knowing the mismatch, I didn't think harping on the issue provided any value in the RoadTest Review. It would have been nice to match the pants with the shirt so to say.
    I am a one tip kinda guy, so a Rest with flexibility to hold multiple bits is redundant. I guess it would be a good place to store a spares.
  • Sean,
    Weller stands usually fit the iron like hand in glove. I think your suspicion - that the stand you have isn't matching the iron - is correct.
    I have an iron, a heat gun and a desolder iron here from Weller (they came in one kit), and they all 3 have different stands that are designed specifically for the tool.
  • I see from the RoadTester listing, ,we are both on the same journey of RoadTest the Weller solder station. Can I get some confirmation/clarification on the components in your system. You make the following commentary in your opening statement that causes me some confusion.
    "The soldering iron station is named the WTP90 which presumably stands for 90W. The version I received uses the short LT series tips. I was surprised to actually find only a single bevel edge tip came with it. The WSR and the WPT80 come in their own boxes."
    I received a WSP80 solder pencil with a WSR200 Safety Rest. The WSR200 Safety Rest packaging indicates the Rest is for the WTP90 solder pencil.
    The whole unit I believe is referenced as a WT1012 and not a WTP90 as you indicate. This link https://www.weller-tools.com/professional/USA/us/Professional/Soldering+technology/Soldering+stations/Soldering+stations…
    on the Weller website seems to confirm my suspicion.
    My WSP80 pencil came with a chisel tip T005 44 405 99 LT B as referenced in the manual.  The test subjects who evaluated the unit would have preferred the concial long tip T005 44 406 99 LT S.  I placed an order for these tips.
    Break..Break...
    Since you have the correct Safety Rest for the solder pencil, can you confirm an operation for me.
    The image is from a tag found with my unit. It does not reflect the Safety Rest configuration I have but does show the barrel and tip assembly.
    If I remove the barrel from the solder pencil, (still containing the tip), and place it vertically in the circle holder on the Safety Rest, the tip rests on the sponge. The distance is not sufficient to keep the tip from touching the sponge. Also the holes in the circle holder that supports the barrel are too large in diameter to hold the tips only, the tips fall through.
    Can you confirm in your Safety Rest does:
    1. the barrel & tip assembly touch the sponge while sitting in the circle holder
    2. the circle holder actually hold a tip without a barrel.
    I made note of the component errors in my review Weller Soldering Station WT Series - Review  but did not include all the above commentary. If the Safety Rest and pencil are a mismatch then issues are due to arise. I'm curious to discover if the difficulties I describe, actually exists when the Safety Stand is matched to the correct solder pencil.
  • I've read all over the Internet that the tips wear out easily, but maybe people lever with them or something, or use some unusual cleaning material. I've never worn out a tip on my solder station - I've accidentally hit one into a desk which had a particularly tiny point (silly size - 0.2mm!) but aside from that, I'm using the same tips I purchased 6 years ago, with the same steel wool that is also 6 years old.
    My regular tip is a 1mm sized one, angle cut off cone style, so still quite small, I use it for through-hole and for SMD work. The other is (I think) just under 3mm, used for large connectors.
    I purchased brass wool, and steel wool at the same time because I didn't know which to choose, and to this day the brass is still in its wrapper, (as are half a dozen tips, waste of money unfortunately). So the wool also seems to last an extremely long time, as you say, that's the thing which should wear out first.
    As a kid, in the UK it was very popular to have Antex non-temperature-controlled irons because they were low-cost and available locally from the electrical stores.. sometimes they would go funny - maybe overheating. No idea. But modern irons are awesome.
  • Brass does not scrape the tip. It’s softer.
    The action of the brass serpentine is catching the solder, not scraping it off,
    You can put the solder tip in and out of the brass thing all day for six year and it’ll be the whool thing that’s gone. Not the tip.
  • For sure, I agree. I cannot comment on production environment tip life performing soldering all day. For development labs (i.e. R&D or developing products), I cannot see the tip wearing out for a decade perhaps with brass wool, given my two tips have lasted for six years on the more aggressive steel wool.
  • A fair comparison would be daily usage under production settings. You'll find out that you'll get nowhere near 6 years. Every time you're using the brass wool, it cleans well but you're also scraping the tip in the process by minute amounts of course which adds up in the long run.
  • I guess it's a very personal opinion, but I too like the wool method for cleaning now, even though I didn't try it for years. Just as a datapoint, I think I've used the wool method for at least 6 years now (for design work, not 9-5 production work), and the iron tips still work like new (I only use two tips, one small one large, and both have been used with wool all this time). This is with a JBC iron not Weller, but I can imagine tip life with Weller products will be just as long.
    I've been using 'inox' or steel wool (more aggressive than brass wool) for the six years, so to me it seems that the brass wool method may likely have no noticeable damage to an iron tip for its entire life.
