RoadTests & Reviews
RoadTests & Reviews
Polls Do you think the ASLK Pro manual requires a revision ?
  • Blogs
  • RoadTests
  • Reviews
  • Author Author: nixiefairy
  • Date Created: 10 Jan 2018 5:47 AM Date Created
  • Last Updated Last Updated: 11 Oct 2021 2:58 PM
  • Views 1809 views
  • Comments 13 comments
ASLK Pro
  • michaelkellett
    michaelkellett over 8 years ago +3
    Which manual ?
  • waelect
    waelect over 8 years ago in reply to nixiefairy +3
    If you want people to vote based on your opinion then only provide the poll on the review only not as a separate post. I based on my opinion one based on Page 16 of the manual that clearly states that…
  • gpolder
    gpolder over 8 years ago in reply to Jan Cumps +3
    Hi Jan, you are right, but I agree with nixiefairy that this manual should do better. For instance the external links in chapter 8 about AGC's points to completely different implementations than used in…
  • gpolder
    Hi Jan,
    you are right, but I agree with nixiefairy that this manual should do better. For instance the external links in chapter 8 about AGC's  points to completely different implementations than used in this chapter. At least a reference should be given to a description of the method used in the experiment.
  • gpolder
    gpolder over 8 years ago in reply to waelect
    there appears to be a small hole in the system, when putting a poll or video in your review it will automatically be published separately.
  • waelect
    If you want people to vote based on your opinion then only provide the poll on the review only not as a separate post. I based on my opinion one based on Page 16 of the manual that clearly states that the Kit is based on instructor lead training, not so much self based training.
    So in saying that, there is sufficient detail as I would expect based on instructor lead projects. As a 4th year engineering student and 30 year veteran as a technician I found it fine for training.  Again my opinion and was separate to any other objective view.
    For hobbyist it is really defined for those with sufficient background to go it alone.
    In summary the kit manual is very much as it is designed for.
    Jan Cumps over 8 years ago in reply to nixiefairy
    that’s how most lab manuals are like, isn’t it (at least when I was a boy image).
    An summary of the calculations and an explanation of the setup. Then a series of lab exercises to be done on that setup.
    I can’t recall a lab manual that went into the theory, because that wasn’t thought in the lab.
  • nixiefairy
    nixiefairy over 8 years ago in reply to waelect
    Hi Malcom,
    Please do have a look through my review : Analog System Lab Kit (STEM Product) - Review
    Nowhere have I mentioned that the kit underperformed. But as a university student, I found the manual to be ill-equipped in the practical approach you mentioned. Most of the manual consists of a re-iteration of the formulas mentioned in the lecture links given in the manual. In fact, few of the formulas given in the manual have not been explained clearly. This is why the manual did cause me some difficulty.
    Regards
  • waelect
    It really depends on the purpose of the kit, teaching university students, It should be a support product not a full teaching aid. Lectures provide a substantial amount of information that is more specialised for degree obtainment. Otherwise do you learn or just follow.
    If it designed for the hobbyist then the manual actually looks complex unless it could be used for aspiring hobbyist to consider getting a degree.
    So my feeling is there is a balance between degree and hobby introduction to theory, too complex and it may push away hobbyist away from the industry.
    Personally it satisfies both areas reasonably well. It maybe too simple for people like myself but I would then use it past my current capabilities, ie: for quick hookup of a design.
    dougw over 8 years ago in reply to nixiefairy
    nixiefairy Thanks - nice write-up.
  • nixiefairy
    nixiefairy over 8 years ago in reply to dougw
    Here you go!
    nixiefairy what has been your experience with it?
  • nixiefairy
    nixiefairy over 8 years ago in reply to michaelkellett
    Just changed the topic, thanks!
