RoadTests & Reviews
RoadTests & Reviews
Polls Out of Curiosity: Why Have Over 200 People Applied for the Weller Soldering Station Roadtest?
  • Blogs
  • RoadTests
  • Reviews
  • Author Author: rscasny
  • Date Created: 19 Dec 2019 9:12 PM Date Created
  • Last Updated Last Updated: 11 Oct 2021 2:59 PM
  • Views 2285 views
  • Comments 18 comments
I roadtest a lot of different kinds of products. Some get a ton of applicants and others I have to "bend arms" a bit to get some people to apply.
My Raspberry Pi and Beaglebone roadtests often get a lot of applicants. Same goes for oscilloscopes and other test equipment.
But 204 applicants for the Weller Solder Station ( Weller Soldering Station WT Series  ) must be the best showing EVER for this kind of product!
So, I'm curious.. What have so many of you applied for this roadtest?
Randall Scasny
RoadTEst Program Manager
  • RoadTest
  • weller
  • soldering station
  • community survey
    dougw over 6 years ago +12
    A soldering iron is perhaps the most important and fundamental tool for anyone building electronics. Everyone needs one. I really wanted to apply but did not apply - because I had already won a lower cost…
  • ntewinkel
    ntewinkel over 6 years ago +9
    I imagine it's due to all of the above, plus it's an accessible RoadTest that more people would be able to take on.
  • 14rhb
    14rhb over 6 years ago +8
    Having good quality tools for any task (whether electronics, engineering, carpentry, painting, mechanics etc) takes away the irritation often linked to substandard tools and therefore makes the task enjoyable…
  • yuricts
    yuricts over 6 years ago
    Wait! Did I miss out on this?? Hmm... got into Element14 too late :-(
  • wolfgangfriedrich
    wolfgangfriedrich over 6 years ago
    All of the above options to vote and all the comments are the correct answer.
    May the force of good solder joints be with you all.
    - W.
  • majanan
    majanan over 6 years ago
    I'm new to the community and thought it would be a good way Into getting involved and completing further road tests/design challenges. Within my "wheelhouse" of expertise and also offers a chance for me to setup a home lab rather than relying on work!
  • trifluoride
    trifluoride over 6 years ago
    I already have two soldering irons but both are geared to solder joints used in the 1990's and earlier. Now I'm back to soldering, after a pause of some 20 years, and would like to use a state-of-the-art iron. Simple as that.
  • colporteur
    colporteur over 6 years ago
    I waited a long time before submitting an application. I had purchased a station a few months ago. After reading comments about the product, I got thinking about a RoadTest review approach. I thought my ideal was novel that might snag me some free stuff for the model railroader club I work with. Who can't use a good solder station?
    I then thought, reflected in another post, this product is ideal to be reviewed by the novice and maybe the selection committee should give newbies some added weight.
    I didn't see GREED on the list and figured I could sugar coat the reason:) Augh crap, rscasny was looking for a mechanism to screen applications and I wrote my own warrant.
  • stevesmythe
    stevesmythe over 6 years ago
    Maybe rscasny you could twist some arms at Weller and politely ask if they could perhaps let you have some more to test! With a whole crowd of people interested, it could be one of their best marketing decisions ever.
    • Vote Up +6 Vote Down
  • luislabmo
    luislabmo over 6 years ago
    I think the reason being is that is a common tool and probably a not-so-complex to review -from my point of view- as it doesn't require a lot of technical knowledge to get started and the required parts to actually use it (solder, parts, wire, PCB) are widely available and cheap.
    Luis
  • easyejl
    easyejl over 6 years ago in reply to Fred27
    I think that's very true too, I see some road tests and think "geez, it would take me 2 months just to figure out a good worthwhile way to test it" but with this you can do some soldering, use an IR temp gauge to check temp rise / decay time, etc. Not a ton of planning required, and the road test could be done pretty thoroughly in just a few hours.
  • easyejl
    These are a spectacular product. The auto shutdown when you put it in the holder makes it very safe for use. Plus I have a bit of different raspberry pi / beaglebone projects i'm working on so I could use a new good soldering iron instead of the cheap junk i'm using to put together the dev boards from kits.
  • 14rhb
    14rhb over 6 years ago in reply to gustavovelascoh
    Just a though. If you are currently using a cheap soldering iron (like many other people) then perhaps you are the exact roadtester they will be looking for. Someone who can explain the benefits of this product compared to alternatives? Such an elated roadtest report might make other readers think about saving and investing in a better solder iron?
    • Vote Up +7 Vote Down
