RoadTests & Reviews
RoadTests & Reviews
Polls Poll: Blockchain is Hot, but I Haven't Gotten Much Interest in the BlockChain Kit Roadtest. Any Ideas Why?
  • Blogs
  • RoadTests
  • Reviews
  • Author Author: rscasny
  • Date Created: 21 Jan 2020 4:39 PM Date Created
  • Last Updated Last Updated: 11 Oct 2021 2:59 PM
  • Views 4563 views
  • Comments 60 comments
If you quickly search through the web, it's clear that blockchain technology is considered as one of the hot new technologies that will find application in a wide number of industries. Some people call it a game changer, which I personally am reluctant to declare. But it definitely is something worth learning more about and understanding how it works. So, when I was approached by a sponsor to launch a roadtest on its new blockchain kit: Infineon Blockchain Starter Kit I thought it was a great idea to roadtest this kit. Now, I will admit I roadtested this a few months ago and I didn't get much interest. I had 5 more kits so I am trying again. I still am not getting much interest. My poll here is to take a sense of why people don't find it interesting. Thanks.
  • community survey
    DAB over 6 years ago +9
    I am still awaiting for someone to explain to me how to use blockchain effectively in a project. I am too old to listen to marketing hype and there has just not been a good engineer explanation that would…
    shabaz over 6 years ago +9
    From what I can tell, the card is more general, and Blockchain is just one scenario, and cryptocurrency applications (which are what are mentioned in the datasheet) are a subset (albeit big and popular…
    Jan Cumps over 6 years ago +8
    I voted other: from checking the documentation, it looks like the kit allows you to validate the solution very well. But I could not find options to work on it from electronics or firmware point of view…
  • easyejl
    easyejl over 6 years ago in reply to gustavovelascoh
    Like with many similar things, it only holds real value once usage hits that critical mass point. Even if they started tracking those things today for every type of the ones you mentioned above, the payoff isn't for years as not that many people are doing searches/transactions on the fresh ones. The real heavy lifting would be in figuring out how and how much of old data to re-record in the block chain
  • gustavovelascoh
    gustavovelascoh over 6 years ago in reply to easyejl
    You are right, everything is still on paper as for now. The advantages are clear, the implementation and deployment aren't.
  • clickio
    clickio over 6 years ago in reply to gustavovelascoh
    Blockchain for the Government sector
    it's more like the 'blockchain for LESS or NO Government' movementimage
  • easyejl
    I haven't seen any actual movement though in terms of it being used image it is the perfect application for it. Self certifying, can check authenticity without needing to check with the government agency. Of course, like anything else, the government officials will find a way to screw it up image
    • Vote Up +5 Vote Down
  • gustavovelascoh
    Actually property title transaction is one of the applications proposed for Blockchain for the Government sector, along with Notary (Birth, marriage, and death transactions), Health records, Voting, and elections.
  • easyejl
    So I've looked at it now and haven't applied. I really only apply for road tests if its something I already have a project that I'm working on that it could be useful for, or if the idea sparks some fun project that will be entertaining.
    Really to me, blockchain's value is in recording proof of transactions, and i'm just not sure how that fits into cards. The thing i'm surprised hasn't been instituted is using blockchain for storing property title transaction info.
  • gecoz
    gecoz over 6 years ago
    Personally, I have to pass on this RoadTest because I know I won't have much time available, which means I would probably not be able to meet the 60 days deadline.
    I remember when this RT was pre-announced (Upcoming RoadTest: Blockchain Security 2Go starter kit), and from the comments made there, and the ones here, it seems to me that the answer to your question is "lack of use cases" for such RoadTest.
    This does not mean the technology is looking for a problem to be solved. Since its inception, Blockchain technology addressed a very clear problem, although a complex one: establishing trust amongst entities that are part of an non-trusted ecosystem.
    Mapping this into use cases that could be used for testing the kit is a completely different problem altogether and, besides being a challenge in itself,  I'm afraid it is also not as exciting as testing other technologies.
    Fabio
  • michaelkellett
    michaelkellett over 6 years ago
    I think the problem with the product (from a Road Test perspective) is that its a very small subset of the bits you need to put together to make a secure system. They've tagged the "Blockchain" word on to try and make it more interesting but it's probably had the opposite effect.
    The cards might be useful if you were already working on a project that needed NFC based IDs talking to Android phones - such a project would most likely involve multiple engineers, and they wouldn't be hanging around to see if they lucked out in a road test or willing to publish if they did.
    clickio makes some good and relevant points about Blockchain in general.
    I'll add my own (from Code Project newsletter last year sometime) "When someone tells you that Blockchain is the solution to X all you really learn is that they know nothing about X"
    MK
    • Vote Up +6 Vote Down
  • COMPACT
    COMPACT over 6 years ago
    It looks fun! Really fun!
  • BigG
    BigG over 6 years ago in reply to clickio
    Stops clones. So would probably work on a game like this...
    https://www.amazon.com/Disney-INFINITY-Starter-Pack-Xbox/dp/B00ASHT3NU
    Reflecting on your comment, I found this sentence on that link you included very illuminating:
    "Infineon’s Blockchain Security 2Go starter kit provides a fast and easy way to build best-in-class security into your blockchain system design."
    So you really need to have a grasp of blockchain system design before you can do anything half decent with this starter kit.
