RoadTests & Reviews
RoadTests & Reviews
Polls Poll: Would You Be Interested in Roadtesting an Edge Processor Based on the Raspberry Pi?
  • Blogs
  • RoadTests
  • Reviews
  • Author Author: rscasny
  • Date Created: 9 Nov 2020 4:36 PM Date Created
  • Last Updated Last Updated: 11 Oct 2021 3:00 PM
  • Views 2041 views
  • Comments 16 comments
The Brainboxes' NeuronEdge Smart Controller is an edge processor based on the Raspberry Pi Compute 3+ module. It was designed to be used in developing and deploying Pi-based solutions seamlessly to Industry. It can sense, sort and send your machine data. It will minimize downtime, speed up response times and maximise profits.
brainboxes bb-400
A few facts ...
  • Smarter machine communication
  • Unlock the data that matters
  • Edge processing with Raspberry Pi
  • Multiple ways to connect within compact DIN mount design
  • Comes with easy to use interface
  • Benefit from Linux and Raspbian open software
  • 8 Digital IO lines
  • 1 Ethernet port for wider network and one for device's own network
  • Detachable Wi-Fi antenna
  • Bluetooth
  • UPS power management
  • Dual redundant 5-30 VDC power supply
  • Raspberry Pi Compute module
  • Edge processing sends relevant data to your application or the cloud
  • Highly compatible open source software
  • Customise with APIs and Dockercontainers
  • Use REST, Websockets, or .NET APIs
  • Program in your favourite language or use out-of-the-box applications
Here's some other resources:
https://www.farnell.com/datasheets/2720409.pdf
https://www.farnell.com/datasheets/2946816.pdf
  • brainboxes
  • bb-400
  • neuronedge
  • roadtest survey
  • rscasny
    rscasny over 6 years ago in reply to cghaba +3
    It's not on the schedule yet. We are exploring the possibility of roadtesting this product. Randall
  • gam3t3ch
    gam3t3ch over 6 years ago +2
    Uh.....sign me up please?
  • mp2100
    mp2100 over 6 years ago in reply to alainlavanchy +2
    The datasheet does not mention I2C. But it's a raspberry pi compute module, so I2C would be internal. They mainly discuss Serial and network connections. There is (apparently) and Arduino inside there…
  • hugohu
    hugohu over 6 years ago
    "It was designed to be used in developing and deploying Pi-based solutions seamlessly to Industry."
    Seems like a third party EV kit for Pi.
    "It can sense, sort and send your machine data."
    Sounds interesting, how does this work?
    "It will minimize downtime, speed up response times and maximise profits."
    As Jan and Scott said those are quite bold claims and and curious on how it can be.
    Perhaps they were able to do some sort of software to speed up? CPU clocking?
    This is powered by the CM3+.
    With an adapter board the CM4 can be fitted with the same port, ws wondering if hardwarely this was compatible with the 4.
  • rsc
    rsc over 6 years ago
    Those are some very bold statements.
  • rscasny
    Randall
  • cghaba
    cghaba over 6 years ago
    Edge processor are hot topic these days. It it the midway solution of processing data acquired from distributed processing or measuring nodes. It reduces nodes complexity and the bandwidth of the transmitted data by doing the processing at the edge between different processes or between processes and cloud.
    When does the roadtest start?
    Jan Cumps over 6 years ago
    How?
  • gam3t3ch
    Uh.....sign me up please? image
