Circuit Protection
Circuit Protection
Forum Have a question about Circuit Protection? Ask our Expert, Abhishek Rao
Join Circuit Protection to participate - click to join for free!
  • Replies 26 replies
  • Subscribers 70 subscribers
  • Views 3671 views
  • expert
  • overcurrent_protection
  • littelfuse
  • circuit_protection
  • question
AbhishekRao
AbhishekRao over 15 years ago
This thread has been closed to new questions.
However, we welcome you to Post Your Question about Power Management in the element14 Community Power Management group. You'll find many fellow members and experts who have just the answer you're looking to find!
Thank You, Your Friends at element14 Community
Abhishek Rao
Abhishek is a technical team lead and has extensive experience and expertise in the field of circuit protection. He holds B.E in Electronics & Telecom Engineering and extends application support for the Littelfuse line of products.
  • AbhishekRao
    AbhishekRao over 14 years ago in reply to e14 Contributor
    Hi Mike,
    We have couple of products, kindly refer the below link:
    http://in.element14.com/jsp/search/browse.jsp?N=202797110054468110170093110148987110324290+110196732&No=0&getResults=true&appliedparametrics=true&locale=en_IN&divisionLocale=en_IN&catalogId=&skipManufacturer=false&skipParametricAttributeId=&prevNValues=202797&mm=1000645||,1001866||,&filtersHidden=false&appliedHidden=false&autoApply=true&originalQueryURL=%2Fjsp%2Fsearch%2Fbrowse.jsp%3FN%3D202797%26No%3D0%26getResults%3Dtrue%26appliedparametrics%3Dtrue%26locale%3Den_IN%26divisionLocale%3Den_IN%26catalogId%3D%26skipManufacturer%3Dfalse%26skipParametricAttributeId%3D%26prevNValues%3D202797
    Thanks & Regards,
    Abhishek.R.Rao
    Technical Support team
    element14
    T: +91 80 40003832
    www.element14.com <http://www.element14.com>
    Disclaimer:
    The ultimate decision on the suitability of parts or advice in the customer's application is solely a decision that should be made by your customer.
    P Please consider the environment before printing this email
    e14 Contributor over 14 years ago in reply to AbhishekRao
    Hi Abhishek.R.Rao
    I copy paste your link and get no results
    Mike
    hi Abishek R Rao
    i need your help to explain me what is reverse current,how did this happen,how to protect the circuit except fuse,what is the effect to the component,
    thank you
    hi Abishek R Rao
    thank you
    hi Abishek R Rao
    thank you
    hi Abishek R Rao
    thank you
  • AbhishekRao
    Hi Sukrihassan,
    Kindly refer the attachment for your query.
    Thanks & Regards,
    Abhishek.R.Rao
    element14
    T: +91 80 40003832
    www.element14.com
    Disclaimer:
    Sent: Fri 4/6/2012 7:20 AM
    To: Abhishek Rao
    Subject: - Re: Have a question about Circuit Protection? Ask our Expert, Abhishek Rao
    created by sukri hassan in Circuit Protection - View the full discussion
    hi Abishek R Rao
    thank you
    Reply to this message by going to element14
    Start a new discussion in Circuit Protection at element14
    To learn how to change your email preferences or stop receiving these messages, click here
    Sitemap | Feedback & Support | Contact Us | Terms of Use | FAQ | About element14
    imageAN636.pdf
    We are stuck with a problem at one of our telecom site installations, currently there are two power sources for charging the battery, one is a wind solar hybrid, and the other is the conventional mains source from rectifier.
    Now at any given point of time only one source should be active, hence we need a automatic change over between these two DC sources, they are rated at 48 volts 100amps each. Can you suggest a solution for this?
    Warm regards,
    Harsh Sheth
  • AbhishekRao
    Hi Harsh,
    For your below application, you can use the DPCO relay.
    Thanks & Regards,
    Abhishek.R.Rao
    element14
    Disclaimer:
    Hello sir I am chethan.
    i need some information regaurding some music ic's and buzzer ckts.i want to learn about and always curious to learn about perticular things.
    sir you might be knowing in this circuits there will be a small round black may be silicon thing from which 11 or more pcb tracks come out,may i know what are they.and where to get info on them.are they ics too.
    i really wnat to know about them
