      • Japan
      • Vietnam
Embedded and Microcontrollers
Embedded Forum GCC Arm toolchain version 14 released
  • Replies 2 replies
  • Subscribers 471 subscribers
  • Views 2600 views
  • gcc
  • c++26
Jan Cumps 11 months ago
Every six months, a new pre-built GCC toolchain for ARM is released. On December 10, release 14.2 Rel1 was published: https://developer.arm.com/downloads/-/arm-gnu-toolchain-downloads.  There are some goodies related to upcoming C++26, such as better support for modules. Check this RedHat blog for an overview of what's in it.
I'm trying to convert a library that I made for GPS communication to modules, and was looking forward to this release. In version 13, I got stuck because of limited support for this. Crossing fingers ...
    Jan Cumps 11 months ago +1
    Here's how to configure Eclipse for building a windows executable : Point to the binaries: Set the dialect: In VSCode, the easiest way to make the IDE discover a cross-compile (arm bare metal) toolchain…
    Jan Cumps 5 months ago +1
    On July 3, release 14.3 Rel1 was published: https://developer.arm.com/downloads/-/arm-gnu-toolchain-downloads .
    Here's how to configure Eclipse for building a windows executable:
    Set the dialect:
    In VSCode, the easiest way to make the IDE discover a cross-compile (arm bare metal) toolchain, is by (temporarily) adding it to your path.
    To set the dialect:
    You may need a recent cmake version (3.13) to use new functionality, such as modukes.
     On July 3, release 14.3 Rel1 was published: https://developer.arm.com/downloads/-/arm-gnu-toolchain-downloads.
