Embedded and Microcontrollers
Embedded Forum What are you programming in?
  • Replies 24 replies
  • Subscribers 506 subscribers
  • Views 2145 views
  • 32bit
  • 32_bit
  • 16_bit
  • programming
  • embedded
  • development
  • programmable_logic
Catwell over 16 years ago
What are you programming in these days? For me it's Assembly and some C/C++. But it seems that it's becoming time to move past all the old tried and true languages for the new. Now you have to know C#.net, Java, and whatever syntax you need for whatever new processor you have to work with. For example, you can't be a straight HTML programmer anymore, you need to know Flash, SQL scripting, CSS, Shockwave, HTML5, and whatever the flavour of the month is, to a high degree of proficiency. It's a lot to know. So, how do you choose what to learn? A few people I knew several years ago were learning Python and Fortran from some reason or other, boasting it's where Engineers have to migrate. Neither of them used those languages. Now they are studying Java and Objective C. To avoid this cycle of learn then learn another, what should we all program in?
Cabe
    0 e14 Contributor over 15 years ago in reply to e14 Contributor
    Roger;
         I stand corrected.  Alan Turing not only broke the German Submarine code while in England but also asked the question, "Can machines think?" in 1950.  Algol 60 was the boutique language when I started programming.  It took a special keyboard, offered extreme speed, and introduced block structuring.  Algol added the backslash to ASCII and was the origin of the construct descriptive language, Backus-Naur form.  BNF was used to describe Pascal which was heavily based on Algol-W.  Algol should definitely have been included in my history.  Algol was the basis for B from which sprang C.  I could use some help with the others however, early European programming developments were often shouded in secrecy.
  • evan.stoddard
    0 evan.stoddard over 13 years ago
    I am mostly an iPhone developer so obj-c with xcode.  But a lot of my clients want their apps to be dynamic so I need to know how to make a backend to the app so I learned php.  I do mostly web design, back end, and Obj-C.  Going with who you said about how you need to know flash for web end stuff.  Actually it is starting to be phased out.  A lot of interactive stuff is now being built with javascript by using jquery.  It is a framework built using javascript.  It is a fantastic library which allows you to do form validation, animation, interactivity, even form submission with lot's less code.
  • johnbeetem
    0 johnbeetem over 13 years ago
    I do most of my programming in GalaxC.  It allows me to define notations that suit my problem domain instead of requiring me to encrypt my problem to suit the language.  This way my programs are more readable and maintainable, and a lot more fun to write.  See http://www.xxicc.org if you're curious.
    Asm, C and Perl for automation FTW.
    I'm in the old school.
