Embedded and Microcontrollers
Embedded Forum Solutions for a very high number of inputs
  • Replies 18 replies
  • Subscribers 505 subscribers
  • Views 2328 views
  • microcontroller
  • electronics
I have a rather ambitious project to get started learning about microcontrollers and embedded systems. I have cheaply acquired an old organ console that is currently analog that i want to convert to digital/MIDI. The MIDI out part seems straightforward enough from a bit of Google searching, but I have no idea how to deal with the seemingly massive number of inputs I need. The current console is wired with a common rail that spans each keyboard, voice bank, etc., then each key is individually wired. The straightforward approach to this would seem to indicate that I need 300+ input connections. I understand the concept of shift registers for pulling in all of those lines, but I'm worried about being able to read them fast enough to get me the nearly real-time response I need to make it a usable musical instrument. Thoughts?
  • D_Hersey
    D_Hersey over 12 years ago +1
    If I knew your circuit topology for your keyboard, I feel I could be more helpful, that said, couple o' deze, meebe: PCA9505/06 :: NXP Semiconductors
  • johnbeetem
    0 johnbeetem over 12 years ago in reply to johnbeetem
    johnbeetem wrote:
    Thank you for your interest.  I probably still have the schematics and a write-up somewhere in my archives.  However, even if I can find it, it's hard copy (predates word processors and schematic editors) so I'd have to get it scanned into a PDF.  Plus, when I see the write-up I may be too embarrassed to share it -- this was some 35 years ago.
    Found it!  I'll get it scanned and upload it to my content.
  • D_Hersey
    0 D_Hersey over 12 years ago
    0 e14 Contributor over 12 years ago in reply to johnbeetem
    0 e14 Contributor over 12 years ago in reply to D_Hersey
    I think you have given good alternative for 88keys, also multi pressed keys are possible with it. this is only input part of my circuit. another part is output of Audio and display for tone ( musical instrument) playing at moment . also MIDI input and output should there.
    Sanjay Limbore
  • D_Hersey
    Okay, well, are the keys, as described, connected to resistive pull-ups to +5V, and SPST PBs to ground?
    Any uP w/ a serial port can do MIDI, from a HW sense.
    The synthesizer internals I would leave to the big boys, probably a PC card.
  • johnbeetem
    Here's my circa 1977 design -- 9 pages of hard copy scanned into a PDF at my local copy shop:  PolyKeyScan.pdf
  • johnbeetem
    0 johnbeetem over 12 years ago in reply to e14 Contributor
    Sanjay Limbore
    I think one can make a decent synthesizer using an ARM Cortex-M4, which has DSP instructions.  There are cheap (in the USA) development boards from ST, TI, and Freescale.  For doing the whole job, I'd suggest an NXP4300 series part that has both a Cortex-M4 for synthesis and a Cortex-M0 to manage overhead functions like keyboard scanning, MIDI, and switch notes on and off.  That way the overhead functions don't glitch the audio.
    A really nice approach is the Numerically Controlled Oscillator (Numerically controlled oscillator - Wikipedia, the free encyclopedia), also known as Direct Digital Synthesis.  NCO/DDS produces a sawtooth waveform which sounds similar to an oboe.  You can quantize it into a square wave which sounds similar to a clarinet, or use the NCO/DDS bits to look up any waveform you like.
  • D_Hersey
    Here is a piece of SW you guys would like, note that it has an FFT button:
    Soundcard Scope
