Embedded and Microcontrollers
Embedded Forum Embedded C book or course
  • Replies 12 replies
  • Answers 4 answers
  • Subscribers 500 subscribers
  • Views 1941 views
  • embedded c
Jairo
Jairo over 1 year ago
Hi, could you recommend me an embedded C book or course?, a time ago I read a book about C but was not oriented to embedded (I work with microcontrollers)
    michaelkellett over 1 year ago +4 suggested
    The general purpose books are fine, and worth reading - if you plan to buy one I suggest at least considering "Modern C, Jans Gustedt, third edition, ISBN 9781633437777", it's only just become available…
  • beacon_dave
    beacon_dave over 1 year ago +2 suggested
    Microchip have some online C programming courses, which may be a starting point or refresher. https://mu.microchip.com/page/development-tools
    shabaz over 1 year ago +2 suggested
    Would also suggest, pick up a couple of normal C and C++ books, plus Python, can recommend the classics Brian Kernighan and Dennis Ritchie as well as Bjarne Stroustrup as well as the very much beginners…
    0 michaelkellett over 1 year ago in reply to kmulier
    Please give an actual example of  "other chapters dive into how that applies on microcontrollers" - I couldn't find any tutorial material that discusses embedded or micro controller programming in C.
    The kind of thing I would expect is, for example, an explanation of how you force an 8 bit read of a hardware register that supports 8 or 16 bit reads with different behaviour.
    But I couldn't find anything other than a very generalised C "manual" and a lot of lists of processors and boards.
    There isn't an index - but I couldn't find an explanation of the volatile keyword in the section on variables.
  • kmulier
    0 kmulier over 1 year ago in reply to michaelkellett
    The index can be found if you scroll down on this page:
    https://embeetle.com/#embedded-dev/c-tutorial
    Here are sections that are specifically aimed at microcontrollers:
    Variables => RAM Memory (see https://embeetle.com/#embedded-dev/c-tutorial/variables)
    Structures => Bit Fields (see https://embeetle.com/#embedded-dev/c-tutorial/structures/bit-fields , also discusses the volatile keyword)
    Unions => Use Case: SFR Register Mapping (see https://embeetle.com/#embedded-dev/c-tutorial/unions)
    You're right that the course material is more focused on the C language itself. Nevertheless, it's still aimed at microcontrollers.
