Embedded and Microcontrollers
Embedded Forum Trouble shifting 5V clock down to 3.3V
  • Replies 12 replies
  • Subscribers 504 subscribers
  • Views 1622 views
Hi Folks.
I have a pwm generated clock from my mcu which is at 5V. I want to step this down to 3.3V. I am using a 2N7000 N channel mosfet and the setup shown below.
This is the square wave generated by the mcu:
When I put it through the level shifter I get This output:
It is clearly offset and very distorted. When I apply 5V directly I get 3.3V out and when I connect ground to it I get 0V out as expected. However when I apply the 0 to 5V square wave it doesn't work.
Does anybody know why this is happening?
Mark.
    michaelkellett over 10 years ago +1
    Do it like this: R1 should be chosen according to frequency - for 50kHz 1k will be acceptable. R2 will not be necessary with a 2n7000 (apply input directly to gate.) This type of level shifter is not very…
    Jan Cumps over 10 years ago +1
    Mark, I've made a few videos on this subject. Having an ugly deformed signal with a voltage divider solution is normal. www.youtube.com/watch www.youtube.com/watch
    shabaz over 10 years ago in reply to e14 Contributor +1
    Bit of a large package(20-pin DIP but SN74LVC244AN SN74LVC244AN is a nice part to have around It is 5V tolerant so good for level conversion particularly if you have many signals
    dougw over 10 years ago
    Perhaps you could simply feed the signal through a couple of diodes with a resistor load to get a 1.4 volt drop.
    A red LED would give a 1.6 volt drop, although it may not be fast enough.
  • D_Hersey
    D_Hersey over 10 years ago
    red led could be fast, though.  Another alternative is to use a resistor and a Zener diode.
