Ask an Expert Forum Have a question about radio or wireless communication?  Ask me!
  • Replies 84 replies
  • Subscribers 347 subscribers
  • Views 9799 views
  • communications
  • pinter_electronics_consultants
  • expert
  • radio
  • wireless
  • chris_pinter
See a helpful answer?
Chris_Pinter
Chris_Pinter over 16 years ago
This thread has been closed to new questions.
However, we welcome you to Post Your Questionabout Communications in the element14 Community Wireless Communications Technology group. You'll find many fellow members and experts who have just the answer you're looking to find!
Thank You, Your Friends at element14 Community
Christopher Pinter
As the founder and President of Pinter Electronics Consultants Chris has been instrumental in developing the business from its inception in 2005 to its current status.  He has over 15 years of experience in radio and wireless communication hardware design and product development. Chris graduated from the Okanagan University with a diploma in Electronic Engineering Technology and the British Columbia Institute of Technology with a Bachelor of Technology in Electronics.
  • Chris_Pinter
    Chris_Pinter over 12 years ago in reply to e14 Contributor
    I do not know if it will work. I would not consider this approach or this project.  I do not see any commercial use.  But if you want to learn something.   Give it a try and find out.
    Hope this helps,
    Chris
    e14 Contributor over 12 years ago in reply to Chris_Pinter
    Thanks again Mr Pinter,
    One last question: what specifically do I need to find out with the spectrum analyzer?  The Vector is definitely well suited for analyzing the bajeezus out of all signals in the room and beyond, but I'll be holding the remote mere centimeters from the antenna.  Could I achieve what I need to with an airView spectrum analyzer?
    Audere est facere!
    José Justiniano
  • Chris_Pinter
    A Spectrum Analyzer only displays the signal.  It will not capture and retransmit It.  Radio development is not for the fault of heart.  from what I understand you want to capture an RC signal,  save it and rebroadcast the information.   This is npt going to be successfully endevour.
    What you need to do is program a device with the information you want to transmit.
    CHris
    Dear Chris,
    I am a pipeline engineer, trying to build what I call "Pipe Radiowave Transmitter and Receivers".
    My test pipeline is 2 inch diameter and 300 m long. About 100 kHz Radiowave signal  from a commercially available RF generator (0.2kHz -2MHz)  is amplified  and aerialed through the pipeline. Receivers are placed at other side. The Transmitter and reciever aerials are install in the pipeline.
    Please see if the Block diagram below make sense to you? What comes out as output of the RF is current that are varying at radio frequency. Is this correct?
    1. Transmitting antenna (about 100kHz. Must be attached to the RF amplifier)
    2. RF signal amplifiers (about 100 watt) compatible with 5
    3. Receiving antenna (broad range of frequencies) -compatible with 4
    4. RF signal analyser (for the received signal)
    5. RF generator (0.2 kHz -2MHz): Spec found: Manufacturer: GW INSTEK, Farnell Order Code: 4911684, Manufacturer Part No: GFG-8015G
    However, we welcome you to Post Your Question about Communications in the element14 Community Wireless Communications Technology group. You'll find many fellow members and experts who have just the answer you're looking to find!
