Ask an Expert Forum expert opinion needed on Raspberry Pi power issue
  • Replies 23 replies
  • Subscribers 341 subscribers
  • Views 4931 views
See a helpful answer?
The Raspberry Pi has an LDO voltage regulator to produce 1.8v.
However, a thermal image of the board, see post #6 on this thread:
http://www.element14.com/community/thread/18991
shows that this regulator, RG1, (the largest blue rectangle in the
upper-left quadrant) to be cool, while the hottest chip is the LAN chip
(SMSC LAN9512).  It turns out that the LAN chip has an internal
1.8v regulator, which user jamodio noticed is apparently connected
to the 1.8v power plane where it normally would be connected
only to decoupling capacitors, not the power plane.  User selsinork
verified that if RG1 is removed completely from the board, the
board still works, apparently drawing all its 1.8v power through
the LAN chip.  User beetem, who first noticed the cool RG1,
has commented on possible problems with having two LDO
regulators operating in parallel like this.
So is this really a problem?  If so, how serious?  Is there an
explanation for why some boards run significantly hotter than
others?  How to get element14's attention?
The latest thread is here:
http://www.element14.com/community/thread/19236?start=15&tstart=0
SMSC datasheet, showing VDD18CORE connected to decoupling
capacitors in Figure 2.2, page 16:
http://www.smsc.com/media/Downloads_Public/Data_Sheets/9512.pdf
Raspberry Pi Schematic 1.0, where top left of page 3 of 5 shows VDD18CORE
connected to +1.8v in addition to decoupling capacitors.
http://www.element14.com/community/solutions/5952
jamodio's original 10 June 2010 report (post #137)
http://www.element14.com/community/message/53280
    Hi Pete,
      It's good to see you back in this forum.
    I'm curious if you have enough data to tell if the temperature
    distribution between different boards is normal (bell curve) or
    bi-modal (hot boards and merely warm boards, but not much
    between).
    I'm also curious if you think the 80mA current that Mackay measured
    at RG1 during startup would be enough to account for the observed
    temperature differences.
    followups can go to the other thread.
  • jamodio
    jamodio over 14 years ago
    We would be able to help more and provide better feedback if RPF decides at some moment to make public updated
    versions of the schematics and Gerber files.
    Also it will be extremely helpful if RPF/distributors develop/put together a ticketing system and knowledge base, this
    thing about tracking bugs/errors, on forums or emails lists does not scale and does not provide any basis for statistics
    or analysis, it is just disorganized techno gossip.
    My .02
    -J
  • jamodio
    jamodio over 14 years ago in reply to e14 Contributor
    PeteL wrote:
    Mike Powell pinged me this thread directly and asked if I could respond, first apologies dropping of the radar (is it really that long!).  I have been looking at board bugs and this one is on my list, notes in my lab so more tomorrow.
    It would be extremely interesting to see what else is on the "list"
    -J
