Ask an Expert Forum BASIC translation to Python
  • Locked Locked
  • Replies 48 replies
  • Answers 24 answers
  • Subscribers 337 subscribers
  • Views 12461 views
  • translation
  • python
See a helpful answer?
tommy2k19
tommy2k19 over 7 years ago
I have written a few very basic programs in Python but have not done much program translation.
My friend asked me to translate his heating program from Basic to Python.
Is there an easy way to do this? I haven't tried anything yet?
Tha Basic code is below:
1:PRINT"HLOSS85.1":PRINT"":GOTO 3
3:"N"INPUT"INPUT NOTES> ";B$(0):PRINT B$(0):GOTO 3
4:PRINT "":IF L>0 END
5:GOSUB 9:GOTO 104
9:PRINT"------------------------":RETURN
10:"=" PRINT=LPRINT:PRINT"":END
20"L"PRINT=PRINT:PAUSE "PO":END
50:"S" CLEAR:USING
60:DIM B$(0)*24
70:DIM S(6),W(6),G(6),V(0),Z(0),P(0),Q(0),O(0),K(0),N(0):N=1:A(27)=25:R=25:T=600
80:M=21:J=-4:U=5.6:A(30)=55:A(32)=3:GOSUB 9:GOTO 1
104:INPUT"INPUT OUTSIDE TEMP C ";J
105:PRINT"OUTSIDE TEMP ";J;" C
106:INPUT"INPUT ROOM TEMP C ";M
107:C=M-J
108:PRINT"PRINT TEMP ";M;" C":PRINT"TD = ";C;" C
114: GOSUB 9
115:"C"B$(0)="":INPUT"INPUT ROOM NAME ";B$(0)
116:IF B$(0)="" GOTO 115
117:IF B$(0)="*" GOTO 320
120:PRINT B$(0)
125:Y$="N":INPUT"SAME AS LAST ROOM? ";Y$;:IF Y$="Y" GOTO 252
130:S(5)=0:P=0:Q=0:B=0:O=0:K=0k:V=0:O(0)=0:K(0)=0:A=0:G(5)=0:W=0
140:USING:L=0:W=0:H=0:INPUT"INPUT ROOM LENGTH M ";L,"INPUT WIDTH M ";W,"INPUT HEIGHT M ";H
165:Z=LW:V=ZH:IF V=0 GOTO 140
175:PRINT"L=";L;"M W=";W;"M H=";H;"M
176:PRINT"AREA ";Z;" M2
177:PRINT"VOLUME ";V; M3
180:S=1
190:S(S)=LH:GOSUB 500
200:S(S)=WH:GOSUB 500
210:S(S)=S(1):GOSUB 500
220:S(S)=S(2):GOSUB 500
230:S(S)=LW:GOSUB 500
240:S(S)=S(5):GOSUB 500
245:USING:D=M-J:INPUT"INPUT AC/HR ";N;"INPUT TD C ";D
246:PRINT N;" A/C @ ";D;" C TD":B=.33VND
247:INPUT"INPUT SAFETY % ";A(33)
248:IF A(33)>100 GOTO 247
249:A(36)=INT B+INT P+INT Q
250:A(34)=INT((A(33)/100)*A(36))
251:PRINT"SAFETY ";A(33);"% ";INT A(34);"W
252:K=INT A(34)+INT A(36)
253:Y$="":INPUT"IS INFO CORRECT ? ";Y$
254:IF Y$="N" GOTO 115
255:IF Y$<>"Y" GOTO 253
256:Z(0)=S(5)+Z(0):P(0)=INT P+P(0):Q(0)=INT Q+Q(0):V(0)=INT B+V(0);O(0)=O+O(0)
257:N(0)=V+N(0):K(0)+K+K(0):A(35)=A(34)+A(35)
258:PRINT"- ROOM HEAT LOSS -
260:PRINT"FABRIC ";INT Q;"W":PRINT"WINDOW ";INT P;"W":PRINT" VENT ";INT B;"W
261:PRINT"SAFETY ";INT A(34);"W
262:PRINT"TOTAL ROOM LOSS ";K;"W
263:IF V=0 GOTO 265
264:PRINT INT ((K/V)+.5);" W/M3
265:GOSUB 9
266:"H"USING:INPUT"INPUT RADIATOR HT MM ";T
267:PRINT"RAD HEIGHT ";T;"MM
268:PRINT"SINGLE ";INT(544K/T);"MM LENGTH
269:PRINT"DOUBLE ";INT(362/T);"MM
270:GOSUB 9
310:GOTO 115
320:PRINT"
330:"G"USING:PRINT:PRINT"-------- TOTALS --------
350:PRINT"FLOOR AREA ";Z(0);" M2
355:PRINT"VOLUME ";N(0);" M3
410:PRINT"FABRIC LOSS ";INT Q(0);"W
420:PRINT"WINDOW LOSS ";INT P(0);"W
430:PRINT"VENT LOSS ";INT V(0);"W
440:PRINT"SAFETY LOSS ";INT A(35);"W
457:GOSUB 9
460;K=INT Q(0)+INT P(0)+INT V(0)+ INT A(35):PRINT "TOTAL LOSS ";INT K;"W
465:PRINT"AV.HEAT LOSS ";INT((K/M-J))+.5);"W/C
467:IF N(0)=0 GOTO 480
468:PRINT" ";INT((K/N(0)))+.5);"W/M3
470:PRINT USING"###.##";"G VALUE ";(K/(M-J))/N(0);" W/M3/C
480:USING:GOSUB 9
484:GOTO 900
489:A(31)=K+A(29)*1E3
490:INPUT"INPUT BOILER MARGIN % ";A(27)
491:A(28)=A(31)*A(27)/1E2
492:PRINT"BOILER MARGIN":PRINT A(27);"% = ";INT A(28);"W
493:GOSUB 9
494:PRINT" BOILER SIZE
495:PRINT USING"#######.#";" ";(A(31)+A(28))/1E3;"KW
496:USING:GOSUB 9
497:PRINT "":PRINT"
498:END
500:IF S<5 PRINT"WALL ";S
502:IF S=5 PRINT"CEILING/ROOF
504:IF S=6 PRINT"FLOOR
505:X=0:G(S)=0:C=M-J
507:INPUT"INPUT FABRIC U VALUE ";X:GOTO 509
508:GOTO 515
509:INPUT"INPUT TD C";C
510:GOSUB 700
512:IF X>0 GOTO 530
515:PRINT"NO LOSS
530:S=S+1:RETURN
700:IF S<6 INPUT"INPUT GLASS AREA M2 ";G(S)
702:IF G(S)>S(S) GOTO 700
705:W(S)=S(S)-G(S):IF W(S)=S(S) GOTO 710
707:IF S<5 LET A=A+S(S)
710:F=W(S)CX:PRINT W(S);"X";X;"X";C;"=";F;"W
712:Q=Q+F
715:IF S(S)=W(S) RETURN
717:INPUT"INPUT GLASS U VALUE ";U
800:IF S=5 PRINT"ROOFLIGHT":GOTO 805
802:PRINT"WINDOW ";S
805:G=G(S)UC
810:PRINT G(S);"X";U;"X";C;"=";G;"W
815:P=P+G:O=O+G(S)
820:K(0)=G(5)
830:RETURN
900:"D"USING:PRINT"D.H.WATER":INPUT"INPUT NO.OF PEOPLE ";I
905:IF I>0 PRINT 920
910:A(29)=0:PRINT"NONE":GOTO 489
920:INPUT"INPUT LITRE/PERSON ";R
930:PRINT I;"PEOPLE X ";R;"LITRE
940:INPUT"INPUT WARMUP - HRS ";A(32)
942:INPUT"INPUT WATER TD C ";A(30)
945:A(29)=4.2A(A30)IR/3600A(32)
950:PRINT A(32);"HR WARMUP @ ";A(30);"C TD
955:PRINT USING"#####.#";HOT WATER CYL";A(29);"KW
970:USING:GOTO 489
975:"X"USING:INPUT"INPUT FLOOR AREA M2";Z(0):PRINT Z(0)
976:INPUT"INPUT VOLUME M3 ";N(0):PRINT N(0)
977:INPUT"INPUT FABRIC W ";Q(0):PRINT Q(0)
978:INPUT"INPUT WINDOW W ";P(0):PRINT P(0)
979:INPUT"INPUT VENT W "V(0):PRINT V(0)
980:INPUT"INPUT SAFETY W ";A(35):PRINT A(35)
995:GOTO "G"
997:"Z"INPUT"INPUT W";K:PRINT K;"W
998:GOTO "H"
  • jomoenginer
    jomoenginer over 7 years ago in reply to tommy2k19 +4 suggested
    There is no GOTO or GOSUB in Python. It is used in C but discouraged in most cases; it is quite common in BASIC. You can think of a GOTO as in an if-elif-else case or just replace the GOTO from BASIC with…
  • jomoenginer
    jomoenginer over 7 years ago in reply to Jan Cumps +4
    Jan Cumps wrote: If it’s a good friend, show this thread. If it is not a very good friend, show the thread then run away . Or it would completely offend the friend and create a negative view of the folks…
  • jc2048
    jc2048 over 7 years ago in reply to Jan Cumps +4 suggested
    The Sharp 1251 seems to have been sold by Tandy rebadged as the PC-3. There's a user manual here that includes a reference for their version of BASIC. https://ia601707.us.archive.org/13/items/PC-3_Owners_Manual_19xx_Tandy…
    0 Jan Cumps over 7 years ago in reply to tommy2k19
    If it’s a good friend, show this thread. If it is not a very good friend, show the thread then run away image.
    0 balearicdynamics over 7 years ago in reply to Jan Cumps
    I totally agree, and despite what kind of friend is, if you show this thread he should become your best friend thankful for the great things he learn from this discussion, his programming style and the incredible skill level of the members of this community. image
  • jomoenginer
    0 jomoenginer over 7 years ago in reply to Jan Cumps
    Or it would completely offend the friend and create a negative view of the folks on this site.
    The OP stated that the code ran on a BBC Micro which was all the rage back the 80's and 90's so the GOTO and GOSUB would have been completely common and perhaps the best the person could do at the time.   All the dude was asking was for some assistance and not a complete bashing of his friends code. Nice.
    0 balearicdynamics over 7 years ago in reply to jomoenginer
    When you start a process, social dynamics are autonomous, you can't expect or do previsions of what will happen image
    0 Jan Cumps over 7 years ago in reply to jomoenginer
    We did the analysis here , showing the flow of control in the original code. I think that that is nice.
    There was a smiley at the end of that line.
  • tommy2k19
    0 tommy2k19 over 7 years ago
    Just to satisfy myself, I am trying to translate it (and I know what you've all said!). But it doesn't seem correct!:
    print "HL0SS85.1":print"":goto(6)
    def goto(5):
        global 6
        line = lineNumber
        lineNumber = 6
    The software is explained here, a bit:
    There is no talk, but after the code is shown, you can see what the input / output looks like, what it does and what it outputs.
    It also scrolls through the documentation.
    At the beginning, the creator says it was written on a morning train trip.
    You can enter room specifics, for multiple rooms (size, what fabric is on the floor, ...).
    It calculates the heat loss, then gives the size of the boiler you'd need to keep the spaces warm.
    About your code to build a GOTO construct in Python, I think it will be easier to try and find the story back in the code
    - how are all those parameters for each room retrieved, and what are those parameters
    - how are the calculations per room made
    - how is the summary calculation done at the end.
    Then abandon the code and implement these 3 functions in Python, using the standard functionality.
    0 Jan Cumps over 7 years ago in reply to Jan Cumps
    If you are using Python 3, someone seems to have implemented a GOTO:
    https://github.com/cdjc/goto
    This one documents it works for 2.6 -> 3.6,
    https://github.com/snoack/python-goto
    How the program presents itself to the user:
    MENU:
    Principles:
    .... etc for each room, see video
    Totals:
  • jc2048
    0 jc2048 over 7 years ago in reply to Jan Cumps
    https://ia601707.us.archive.org/13/items/PC-3_Owners_Manual_19xx_Tandy/PC-3_Owners_Manual_19xx_Tandy_text.pdf
