Ask an Expert Forum BASIC translation to Python
  • Locked Locked
  • Replies 48 replies
  • Answers 24 answers
  • Subscribers 337 subscribers
  • Views 12510 views
  • translation
  • python
See a helpful answer?
tommy2k19
tommy2k19 over 7 years ago
I have written a few very basic programs in Python but have not done much program translation.
My friend asked me to translate his heating program from Basic to Python.
Is there an easy way to do this? I haven't tried anything yet?
Tha Basic code is below:
1:PRINT"HLOSS85.1":PRINT"":GOTO 3
3:"N"INPUT"INPUT NOTES> ";B$(0):PRINT B$(0):GOTO 3
4:PRINT "":IF L>0 END
5:GOSUB 9:GOTO 104
9:PRINT"------------------------":RETURN
10:"=" PRINT=LPRINT:PRINT"":END
20"L"PRINT=PRINT:PAUSE "PO":END
50:"S" CLEAR:USING
60:DIM B$(0)*24
70:DIM S(6),W(6),G(6),V(0),Z(0),P(0),Q(0),O(0),K(0),N(0):N=1:A(27)=25:R=25:T=600
80:M=21:J=-4:U=5.6:A(30)=55:A(32)=3:GOSUB 9:GOTO 1
104:INPUT"INPUT OUTSIDE TEMP C ";J
105:PRINT"OUTSIDE TEMP ";J;" C
106:INPUT"INPUT ROOM TEMP C ";M
107:C=M-J
108:PRINT"PRINT TEMP ";M;" C":PRINT"TD = ";C;" C
114: GOSUB 9
115:"C"B$(0)="":INPUT"INPUT ROOM NAME ";B$(0)
116:IF B$(0)="" GOTO 115
117:IF B$(0)="*" GOTO 320
120:PRINT B$(0)
125:Y$="N":INPUT"SAME AS LAST ROOM? ";Y$;:IF Y$="Y" GOTO 252
130:S(5)=0:P=0:Q=0:B=0:O=0:K=0k:V=0:O(0)=0:K(0)=0:A=0:G(5)=0:W=0
140:USING:L=0:W=0:H=0:INPUT"INPUT ROOM LENGTH M ";L,"INPUT WIDTH M ";W,"INPUT HEIGHT M ";H
165:Z=LW:V=ZH:IF V=0 GOTO 140
175:PRINT"L=";L;"M W=";W;"M H=";H;"M
176:PRINT"AREA ";Z;" M2
177:PRINT"VOLUME ";V; M3
180:S=1
190:S(S)=LH:GOSUB 500
200:S(S)=WH:GOSUB 500
210:S(S)=S(1):GOSUB 500
220:S(S)=S(2):GOSUB 500
230:S(S)=LW:GOSUB 500
240:S(S)=S(5):GOSUB 500
245:USING:D=M-J:INPUT"INPUT AC/HR ";N;"INPUT TD C ";D
246:PRINT N;" A/C @ ";D;" C TD":B=.33VND
247:INPUT"INPUT SAFETY % ";A(33)
248:IF A(33)>100 GOTO 247
249:A(36)=INT B+INT P+INT Q
250:A(34)=INT((A(33)/100)*A(36))
251:PRINT"SAFETY ";A(33);"% ";INT A(34);"W
252:K=INT A(34)+INT A(36)
253:Y$="":INPUT"IS INFO CORRECT ? ";Y$
254:IF Y$="N" GOTO 115
255:IF Y$<>"Y" GOTO 253
256:Z(0)=S(5)+Z(0):P(0)=INT P+P(0):Q(0)=INT Q+Q(0):V(0)=INT B+V(0);O(0)=O+O(0)
257:N(0)=V+N(0):K(0)+K+K(0):A(35)=A(34)+A(35)
258:PRINT"- ROOM HEAT LOSS -
260:PRINT"FABRIC ";INT Q;"W":PRINT"WINDOW ";INT P;"W":PRINT" VENT ";INT B;"W
261:PRINT"SAFETY ";INT A(34);"W
262:PRINT"TOTAL ROOM LOSS ";K;"W
263:IF V=0 GOTO 265
264:PRINT INT ((K/V)+.5);" W/M3
265:GOSUB 9
266:"H"USING:INPUT"INPUT RADIATOR HT MM ";T
267:PRINT"RAD HEIGHT ";T;"MM
268:PRINT"SINGLE ";INT(544K/T);"MM LENGTH
269:PRINT"DOUBLE ";INT(362/T);"MM
270:GOSUB 9
310:GOTO 115
320:PRINT"
330:"G"USING:PRINT:PRINT"-------- TOTALS --------
350:PRINT"FLOOR AREA ";Z(0);" M2
355:PRINT"VOLUME ";N(0);" M3
410:PRINT"FABRIC LOSS ";INT Q(0);"W
420:PRINT"WINDOW LOSS ";INT P(0);"W
430:PRINT"VENT LOSS ";INT V(0);"W
440:PRINT"SAFETY LOSS ";INT A(35);"W
457:GOSUB 9
460;K=INT Q(0)+INT P(0)+INT V(0)+ INT A(35):PRINT "TOTAL LOSS ";INT K;"W
465:PRINT"AV.HEAT LOSS ";INT((K/M-J))+.5);"W/C
467:IF N(0)=0 GOTO 480
468:PRINT" ";INT((K/N(0)))+.5);"W/M3
470:PRINT USING"###.##";"G VALUE ";(K/(M-J))/N(0);" W/M3/C
480:USING:GOSUB 9
484:GOTO 900
489:A(31)=K+A(29)*1E3
490:INPUT"INPUT BOILER MARGIN % ";A(27)
491:A(28)=A(31)*A(27)/1E2
492:PRINT"BOILER MARGIN":PRINT A(27);"% = ";INT A(28);"W
493:GOSUB 9
494:PRINT" BOILER SIZE
495:PRINT USING"#######.#";" ";(A(31)+A(28))/1E3;"KW
496:USING:GOSUB 9
497:PRINT "":PRINT"
498:END
500:IF S<5 PRINT"WALL ";S
502:IF S=5 PRINT"CEILING/ROOF
504:IF S=6 PRINT"FLOOR
505:X=0:G(S)=0:C=M-J
507:INPUT"INPUT FABRIC U VALUE ";X:GOTO 509
508:GOTO 515
509:INPUT"INPUT TD C";C
510:GOSUB 700
512:IF X>0 GOTO 530
515:PRINT"NO LOSS
530:S=S+1:RETURN
700:IF S<6 INPUT"INPUT GLASS AREA M2 ";G(S)
702:IF G(S)>S(S) GOTO 700
705:W(S)=S(S)-G(S):IF W(S)=S(S) GOTO 710
707:IF S<5 LET A=A+S(S)
710:F=W(S)CX:PRINT W(S);"X";X;"X";C;"=";F;"W
712:Q=Q+F
715:IF S(S)=W(S) RETURN
717:INPUT"INPUT GLASS U VALUE ";U
800:IF S=5 PRINT"ROOFLIGHT":GOTO 805
802:PRINT"WINDOW ";S
805:G=G(S)UC
810:PRINT G(S);"X";U;"X";C;"=";G;"W
815:P=P+G:O=O+G(S)
820:K(0)=G(5)
830:RETURN
900:"D"USING:PRINT"D.H.WATER":INPUT"INPUT NO.OF PEOPLE ";I
905:IF I>0 PRINT 920
910:A(29)=0:PRINT"NONE":GOTO 489
920:INPUT"INPUT LITRE/PERSON ";R
930:PRINT I;"PEOPLE X ";R;"LITRE
940:INPUT"INPUT WARMUP - HRS ";A(32)
942:INPUT"INPUT WATER TD C ";A(30)
945:A(29)=4.2A(A30)IR/3600A(32)
950:PRINT A(32);"HR WARMUP @ ";A(30);"C TD
955:PRINT USING"#####.#";HOT WATER CYL";A(29);"KW
970:USING:GOTO 489
975:"X"USING:INPUT"INPUT FLOOR AREA M2";Z(0):PRINT Z(0)
976:INPUT"INPUT VOLUME M3 ";N(0):PRINT N(0)
977:INPUT"INPUT FABRIC W ";Q(0):PRINT Q(0)
978:INPUT"INPUT WINDOW W ";P(0):PRINT P(0)
979:INPUT"INPUT VENT W "V(0):PRINT V(0)
980:INPUT"INPUT SAFETY W ";A(35):PRINT A(35)
995:GOTO "G"
997:"Z"INPUT"INPUT W";K:PRINT K;"W
998:GOTO "H"
  • jomoenginer
    jomoenginer over 7 years ago in reply to tommy2k19 +4 suggested
    There is no GOTO or GOSUB in Python. It is used in C but discouraged in most cases; it is quite common in BASIC. You can think of a GOTO as in an if-elif-else case or just replace the GOTO from BASIC with…
  • jomoenginer
    jomoenginer over 7 years ago in reply to Jan Cumps +4
    Jan Cumps wrote: If it’s a good friend, show this thread. If it is not a very good friend, show the thread then run away . Or it would completely offend the friend and create a negative view of the folks…
  • jc2048
    jc2048 over 7 years ago in reply to Jan Cumps +4 suggested
    The Sharp 1251 seems to have been sold by Tandy rebadged as the PC-3. There's a user manual here that includes a reference for their version of BASIC. https://ia601707.us.archive.org/13/items/PC-3_Owners_Manual_19xx_Tandy…
    0 Jan Cumps over 7 years ago in reply to Jan Cumps
    On a related topic, I'm porting a python program to Java (for a roadtest).
    Although the program is well structured and uses classes, it isn't straightforward.
    The way I'm trying to do this is by first creating the same objects as in the python design, then adding and porting the methods one by one.
    Here is an example of my approach.
    Left original python (from Gough Lui and Harting), right java
    Classes have the same name where possible.
    I replaced the parse_xx function by Parserxx classes (each implementing the Parser interface that I also created).
    Where I haven't ported the code, I place a //todo: comment - so I can search for them later.
    I do function by function, object by object. And test often during the exercise.
    ... after refactoring:
  • fmilburn
    0 fmilburn over 7 years ago in reply to Jan Cumps
    Hi Jan,
    You should get the helpful member of the month award for your responses and help on this question.  I had a Sharp-1251 back in the day but had forgotten about it until I saw this thread.  Amazing that there is an emulator for it.
  • jomoenginer
    0 jomoenginer over 7 years ago in reply to fmilburn
    fmilburn  wrote:
    Hi Jan,
    I second the Nom.
  • tommy2k19
    0 tommy2k19 over 7 years ago in reply to jc2048
    I am seeing my friend today, so I shall discuss with him.
  • basic2python
    0 basic2python over 1 year ago
    I stumbled across this post 2 years ago, looking for automated BASIC to Python conversion for an old BASIC project.
    I couldn't find a suitable automated conversion. So I researched transpilers, decided it was more work that it was worth and shelved the project. (If you interested in writing your own transpiler/converter, see "If you are interested in writing your own transpiler" below).
    But, a lot has changed in the last 2 years. Fortunately, you don't need to write a transpiler or perform the translation yourself.
    I prompted ChatGPT's Code Copilot (based on GPT-4 6/28/2024) to convert the HLOSS85 program to Python.
    It provided surprisingly good answers:
    * it generated an outline, and initial program revision.
    * when prompted, it performed some basic data flow and code flow analysis, and identified code blocks.
    * it interpreted variables and code blocks and provided explanations.
    * it detected and fixed some errors without any prompting.
    * working interactively with it, it added more functionality, fixed bugs and clarified original program functionality.
    The bad news is that it did not provide a complete, correct program from the initial prompt. I think that's too much to expect.
    Anyone attempting to use ChatGPT (or similar LLM) will still need to be able to understand both the original and AI-generated code, and be able to debug both.
    But, the good news is that ChatGPT Code Copilot seems to be able to significantly accelerate the process of program conversion.
    If you are interested in writing your own transpiler, read on.
    I found some good info on writing transpilers and why there probably aren't very many for BASIC-to-Python conversion (tomassetti.me/.../)
    Here are some links about transpilers:
    Tomassetti: How to Write a Transpiler (tomassetti.me/.../ )
    Terence Parr: Language Translation using ANTLR (theantlrguy.atlassian.net/.../Language Translation Using ANTLR and StringTemplate)
    If you're unfamiliar with these topics, this is a gentle introduction to scanning, parsing, compiling and interpreting:
    Spivak's Let's Build a Simple Interpreter (ruslanspivak.com/.../)
    Here is an example TI84 BASIC-to-Python open source transpiler project, written in Python: TabulateJarl8's ti842py project (github.com/.../ti842py)
    Automated transpiling of unstructured BASIC to python is difficult because there are 2 problems to address:
    1. removing the GOTO statements and transforming the program into structured code, and
    2. translating the BASIC program to Python
    There are lots of resources for automating the removal of GOTO statements. Here are a few:
    * www.researchgate.net/.../2644650_A_Goto-Elimination_Method_And_Its_Implementation_For_The_McCat_C_Compiler
    * www.researchgate.net/.../2609386_Taming_Control_Flow_A_Structured_Approach_to_Eliminating_Goto_Statements
    * www.ndss-symposium.org/.../11_4_2.pdf
    * Aho, Lam, Sethi, Ullman 2006, aka, "the purple dragon book", ch. 9.7.3 Region-Based Analysis; T1-T2 Reduction algorithm
    If you are serious about writing a BASIC-to-Python conversion program yourself, you'll probably want to:
    a. parse the BASIC program into an abstract program representation
    b. remove GOTO statements, transforming the program into a structured program
    c. generate Python code from the abstract structured program
  • basic2python
    0 basic2python over 1 year ago in reply to basic2python
    Unfortunately, I could not figure out how to edit my previous post.
    2 of the links above were incorrectly constructed - the trailing parenthesis ')' was incorrectly appended to those URLs.
    The correct URLs are:
    Tomassetti: How to Write a Transpiler: https://tomassetti.me/how-to-write-a-transpiler/
    Parr: Language Translation Using ANTLR and StringTemplate: https://theantlrguy.atlassian.net/wiki/spaces/ST/pages/1409118/Language+Translation+Using+ANTLR+and+StringTemplate
    Spivak: Let's Build a Simple Interpreter: https://ruslanspivak.com/lsbasi-part1/
    TabulateJarl8: project ti842py: https://github.com/TabulateJarl8/ti842py
    "A Goto-Elimination Method And Its Implementation For The McCat C Compiler", Erosa: https://www.researchgate.net/publication/2644650_A_Goto-Elimination_Method_And_Its_Implementation_For_The_McCat_C_Compiler
    "Taming Control Flow: A Structured Approach to Eliminating Goto Statements", Erosa, Hendren: https://www.researchgate.net/publication/2609386_Taming_Control_Flow_A_Structured_Approach_to_Eliminating_Goto_Statements
    "No More Gotos", Yakdan, Eschweiler, Gerhards-Padilla, Smith: https://www.ndss-symposium.org/wp-content/uploads/2017/09/11_4_2.pdf
