Ask an Expert Forum Toroid Rings.
  • Replies 24 replies
  • Answers 13 answers
  • Subscribers 316 subscribers
  • Views 4043 views
See a helpful answer?
Toroid Rings.
johnsmalley
johnsmalley over 6 years ago
Choosing the correct toroid ring.....
I’d like guidance on choosing the best component for a try at making a 60KHz RF amplification strip for a (kind of) TRF radio receiver. Having tried to study the topic, I think I now know less than I did to begin with! image
As a starting point consider the cost as no object, and a selection can only be made from the stock list of Farnell, with whom I have a trade A/C. The overriding need - as I understand it - will be for the best possible Q.
I have a small selection of ‘magnet wire’ + some 68 x 0.04mm Litz wire.
Wisdom, guidance, etc, most gratefully received.
Thanks.
    michaelkellett over 6 years ago in reply to shabaz +5 suggested
    A toroid won't work like a ferrite rod aerial - put simply there is no way for the magnetic component of the RF to get into the core and generate emf in the coil;. I was interested in this too - so I've…
  • johnsmalley
    johnsmalley over 6 years ago in reply to 14rhb +5 suggested
    Guys .... Thanks for the responses. Just to clear it up, I’m *not* trying to use a toroid core as an antenna. I’ll mess with a ferrite rod for that. The toroids are for a kind of IF strip but, of course…
  • 14rhb
    14rhb over 6 years ago in reply to johnsmalley +5 suggested
    I'm old too . I think your question has been answered in my absence by several knowledgeable Element14 members. The blogs are a nice way of sharing our fun and experiences in electronics (and related disciplines…
    0 shabaz over 6 years ago in reply to michaelkellett
    Hi Michael, Oh that's a shame. They were of a decent length too.
    I tried a whip antenna just now into a HF receiver to see if it would pick it up in CW mode to record a WAV file in case it helps for your code. I've put the zipped-up MSF wav file here it is recorded from about 12:11 BST (11:11 UTC) today (Fri 4th 0ct 2019) and the recording is just over four minutes long. The receiver was in CW mode, set to 1kHz tone. The tone is audible, but would need some signal processing (the antenna wasn't very good, it was just a short length antenna).
    EDIT: After some filtering in an audio app (I don't have matlab on this PC) this is the spectrum, for about 5 seconds. The horizontal scale is seconds, i.e. running from 30.0 sec to 35.2 sec. The carrier off period is visible, seems to be off-periods of 200, 200, 300, 300, 300 msec in this portion.
  • johnsmalley
    0 johnsmalley over 6 years ago in reply to michaelkellett
    Thanks for the data sheet link. I’ve downloaded it, thanks.
    Before going much further I’m going to see if I can discover what sort of Q I should be aiming for. Within reason the higher the better, maybe? I suppose radio constructors’ books, etc, from the 1940s might help - if I can get them - and there is the RSGB and ARRL publications.
    Thanks again for the link: all this stuff is useful!
    Best
    J
  • johnsmalley
    What a mess with the rods! Can’t understand why these folk have such a lack of comprehension when it comes to packing fragile stuff for the post.
  • 14rhb
    0 14rhb over 6 years ago in reply to michaelkellett
    That's awful. Clicking 'like' seemed slightly inappropriate - what I really meant by clicking is support for you.
    I'm assuming you didn't order these from Farnell/Avnet/Element14 - their packing always seems good.
