Ask an Expert Forum Identify a burnt & disfigured IC chip on power board of DVD player
  • Replies 12 replies
  • Answers 6 answers
  • Subscribers 339 subscribers
  • Views 6655 views
See a helpful answer?
npsp
npsp over 6 years ago
Recently the DVD player heard a loud ping and loss of power to it. I removed the cover of that player found the power panel with fused & IC chip burned. I can't identify the chip due to the numbers being burned . I would like to seek your assistance in identifying the chip for replacement. Thank u.imageimage
  • npsp
    npsp over 6 years ago in reply to dougw +3
    Yes this is from a DVD player by the brand martin ranger, it's the power supply board . I wasn't good with identifying the ic chip , will try to research abit of those.
    michaelkellett over 6 years ago in reply to npsp +3 suggested
    It certainly looks like a mains to DC converter - the optocoupler and transformer rather confirm it. Your next step should be to trace out the complete circuit and draw a schematic of it - it looks like…
    michaelkellett over 6 years ago in reply to dougw +3 suggested
    Sorry Doug, I'm missing something here. I can find the data sheet for the DK1203 and it's a flyback mains to low voltage regulator for optocoupled feedback in an 8 pin DIL package as I'd expect. I can…
    0 michaelkellett over 6 years ago in reply to npsp
    You would only get a problem if the DVD needs more current than the power supply is rated for.
    Once you install the board you can check the supplies with a meter.
    There is still a risk that fault in the DVD caused the power supply to fail - the only way to check this would be to power up the DVD using other supplies but they should really by lab type supplies with meters and current limiting. If you don't have access to these then just turn the new supply on briefly and turn it off if the DVD doesn't work. Do be very careful to get the right voltages onto the DVD pins (I expect you know that !).
  • 14rhb
    0 14rhb over 6 years ago in reply to dougw
    I'm not sure you've posted your intended link, it seems completely different to the DK1203.
