Ask an Expert Forum Help with fuse resistors please to fix a tape deck
  • Replies 21 replies
  • Subscribers 338 subscribers
  • Views 7773 views
See a helpful answer?
raymate
raymate over 4 years ago
Im new to electronics and I have an old cassette tape deck that I was getting going but managed to short something and burnt out a fuse resistor.
Now we are dealing with a tape deck thats 30 years old so no one will fix it in my area so im learning to try and fix it myself.
So I checked continuity and found the resistor that has blown I also saw smoke come from it when I killed it so im pretty sure I just need to replace it.
The service manual says its a " fusible resistor 1.5 5% (1/2W) F " located at R736 but when I look at the resistor on the board it seems to be 2.2 not a 1.5  .....  if I'm reading the resistor right?
This is the help I need, is this dead one on the board 2.2 or 1.5  ,  could it be possible they used 2.2 not a 1.5 as I think its just acting as a fuse. Should I put back what the service manual says or the same as what already in place.
Attached the picture of the resistor thats dead on the board and has no continuity, i ordered online what the service manual says and what I think is the direct replacement for whats still on the board.
So I purchased three resistors types 1.5 and 2.2 (and another 2.2 from a different vendor) also the new ones are so much smaller I guess thats OK things have moved on in 30 years.
So I would like to know have I purchased the right thing. Im just confused as the new ones seems to have arrived with 5 bars.
One I purchased said its a " res 2.2 OHM 5% 1/2W AXIAL " (this is the smaller one in the picture) the other larger ones are generic from ebay.
Thanks for your help, I know this is basic stuff.
  • Andrew J
    Andrew J over 4 years ago +2
    It's possible someone has bodged a 2.2Ohm resistor in there in the past - have you had the cassette deck from new? A fusible resistor should have a white band around it (maybe, see below), like your smaller…
  • raymate
    raymate over 4 years ago in reply to Jan Cumps +2
    One of the motors in the deck is not spinning so I was probing the motor terminals and it did show me 11.5v going to the motor which is correct but for some reason I was checking it again to make sure…
    Jan Cumps over 4 years ago +1
    Can you post the info from the service manual, and the schematic that shows this component? Did it work before you caused the smoke? What did you do that generated the smoke? What components do you think…
  • raymate
    Cool, the 570 is basically the same deck as mine with a little different mechanism.... would you believe it I paid $15 for it in a thrift store, so with belts new motor and fuse, its still less than $100 for a deck of this caliber. Just hope nothing else is dead.
    What are the chances someone helping having almost the same deck Slight smile
    Jan Cumps over 4 years ago in reply to raymate
    I have no experience with fusable resistors. In this scenario the 700 miliohm difference will likely not make the difference, because the motor has a speed setting screw (if I recall well).
    Anyways, it's a later addition, because the first batches also used 12.2 V with the same motor, and they didn't have this fuse.
  • raymate
    Yes it does have a speed adjuster. OK sounds good I will just use the 2.2 ohm they seems decent quality. And as a friend said to me it probably doesn't matter its only there to stop people like me doing damage.... Slight smile
    In unknown condition, they also go about 15 to 20 € here. I saw in my mail that I sold the 630, in good working order and serviced, for 150 € in '14.
  • Andrew J
    Andrew J over 4 years ago in reply to raymate
    2.2ohms clearly works but the fusible resistor is meant to handle in-rush current.  Like Jan, I don’t know anything about fusible resistors but you may want to check the current ratings between the 2.2 and a select number of 1.5 examples to see if there’s any significant difference.  It’s not even clear from your photo that the one currently soldered into the board is a fusible one!!
    Size of the resistor shouldn’t matter as long as it meets the service manual spec.  Let us know how you get along.
    Jan Cumps over 4 years ago in reply to Andrew J
    My wild guess is that Sony went from no fuse first, to 1.5 ohm at the time the service manual was released, to 2.2 ohm at the time this particular desk was built.
    It looks to be an aftertought added after this series went in production. Likely after they had defect reports from their repair service partners that there was a repeat issue in that part of the circuit.
  • raymate
    raymate over 4 years ago in reply to Andrew J
    Thank you for the reply. This is my first time on this forum and its been a great experience. Once the motor arrives and installed I shall report back. Thanks again for the information.
  • raymate
    raymate over 4 years ago in reply to raymate
    Sounds logical to me, thank you for your help
  • raymate
    Wow you will be lucky to get them that price now, this deck I have on ebay broken its about $200 and working around $600, 3-head decks are stupid money now on ebay. Any ES deck is at least $ 400-600
  • Andrew J
    Andrew J over 4 years ago in reply to Jan Cumps
    Could well be.  You’d think Sony would update the service manual.  I wonder if there is a later revision floating around on the web.
