Ask an Expert Forum GPS antenna value not coming
  • Replies 12 replies
  • Subscribers 335 subscribers
  • Views 3918 views
  • gps
  • antenna
See a helpful answer?
narendra_sixsense
narendra_sixsense over 3 years ago
Hi, team,
We recently purchased this gps antenna chip https://in.element14.com/molex/204283-0001/omni-antenna-lin-1-597-1-607ghz/dp/2855754
And : https://in.element14.com/pulse-larsen-antennas/w3011a/gps-ceramic-chip-antenna-1-57542/dp/2897228
to use this with simcom module A7672s as a passive antenna.
we soldered this as per footprint, we tried both antenna on two separate PCBs we designed with different footprint as per datasheet , but no gps values coming, please help us, whether or how these gps worked ?
Please send, if anyone have any tested reference schematic layout.
  • jc2048
    jc2048 over 3 years ago in reply to ashutamar +2
    This is the Molex recommended layout. www.molex.com/.../2042830001-AS.pdf Your photograph isn't very clear, but it looks like you have ground copper under the antenna. I'm not an rf specialist…
  • jc2048
    jc2048 over 3 years ago +1
    Are you sure that the module you've got can even do this? I didn't investigate too far, but the manufacturer's site says GNSS is offered as an 'option' with these modems.
    shabaz over 3 years ago in reply to ashutamar
    Looks like the antenna datasheet was completely ignored. Someone with no idea seems to have tacked that antenna onto the existing project? I think they need to read the datasheet and follow it; it specifies what clearances and ground plane and matching is needed. All of that was ignored by whoever modified the PCB.
  • jc2048
    I'm not an rf specialist (just someone trying to be helpful), but I don't think what you've done will work. The only time you'll get away with metal under a board antenna is with a true patch antenna, where the antenna itself has a internal ground plane (so what's underneath doesn't matter), but this isn't a patch antenna.
