Ask an Expert Forum How to use an IC with this packaging
  • Replies 12 replies
  • Subscribers 332 subscribers
  • Views 3082 views
  • help
  • prototyping
  • soldering
See a helpful answer?
yosoufe
yosoufe over 3 years ago
I have an IC with the following packaging. It is weird that it has two sections. How should I use it? Can I just cut the second part?
Here is the datasheet of the IC: https://www.allegromicro.com/~/media/Files/Datasheets/ATS668-Datasheet.ashx
I am still prototyping with it. Like on a breadboard or like that.
  • Gough Lui
    Gough Lui over 3 years ago +7
    You would cut off the bar and that would leave you 2.4mm pitch. If you cut above the knee, then that leaves you with 1.27mm pitch. - Gough
    shabaz over 3 years ago +3
    Hi, You can just bend or cut it off. It's supplied like that because some manufacturers may mount these sideways on a PCB, and the leads might accidentally be bent if it wasn't on that strip, which would…
  • yosoufe
    yosoufe over 2 years ago +3
    I ended up using it like this Keeping the protection as is on the PCB.
  • anniel747
    anniel747 over 2 years ago in reply to yosoufe
    [deleted]
  • yosoufe
    yosoufe over 2 years ago in reply to anniel747
    Anyway, the current speed control doesn't output that even if it can do that which I doubt.
