Ask an Expert Forum Use sound exicter to produce vibration with esp32
  • Replies 23 replies
  • Subscribers 336 subscribers
  • Views 6219 views
See a helpful answer?
AndrewT
AndrewT over 3 years ago
Hi everyone! I want to use a sound exciter as a haptic motor which produces the vibration. However, it always makes some noise.
How can I reduce the noise as much as possible? eg the editing program.
Thank you!
  • BigG
    BigG over 3 years ago +3
    Sound exciters only make a noise because the wave form it produces resonates across a surface. Thus if you removed the sound exciter from any surface it won't make much noise. Similarly, if you placed…
    shabaz over 3 years ago in reply to AndrewT +2
    Impressed at the 279 euro price tag! It's overpriced by about 250 euro, considering it's just a small Bluetooth speaker with perhaps a few motors added too, and a bit of basic signal processing. Although…
    michaelkellett over 3 years ago +1
    The clue is in the name a sound exciter (AKA a loudspeaker) is designed to make a noise ! A vibration exciter is designed to make vibration. There are loads on Ebay and Amazon, not expensive. This…
  • anniel747
    anniel747 over 3 years ago in reply to michaelkellett
    There is also the bass shakers that are somewhat in-between the sound and vibration exciters.
    Jan Cumps over 3 years ago in reply to anniel747
    balearicdynamics and I made one:  Field Trip to Enrico and the Ingegno Maker Space
  • anniel747
    anniel747 over 3 years ago in reply to Jan Cumps
    Did you try it out as a Chladni plate?
  • BigG
    Similarly, if you placed a haptic motor on a cardboard box then it too will make noise as the high frequency vibrations resonate across the cardboard surface.
    So if you set a constant frequency and control the amplitude of the sound wave through the sound exciter then it will mimic a vibration effect at that set frequency.
  • Electrojim
    Electrojim over 3 years ago
    What sort of waveform you are driving the exciter with?  What you perceive as 'noise' could simply be the sharp edges of a digitally-generated synthesized low frequency waveform. For instance, a 20Hz sine wave is a pure tone that would vibrate a surface or mass at only 20Hz, which you probably would not hear. But if you are using a square waveform there are harmonics at multiples of 20Hz which will sound like someone knocking on your front door 40 times a second (one knock when the drive goes positive, one knock when it goes negative).  Run your signal through a low-pass filter and see if that helps reduce the audible noise component.
  • davebullockmbe
    davebullockmbe over 3 years ago
    Theres always an alternative approach www.bristol.ac.uk/.../
    no Slight smile
  • anniel747
    anniel747 over 3 years ago in reply to davebullockmbe
    Some military applications use that also.
  • AndrewT
    AndrewT over 3 years ago in reply to anniel747
    https://www.daytonaudio.com/product/1296/daex-13-4sm-haptic-feedback-and-audio-exciter-13mm-3w-4-ohm
    I find that it can be a sound exciter and Haptic Feedback.
    But I want to make it as a haptic feedback.Therefore, I hope that can minimize the noise and have strong vibration
  • AndrewT
    https://feelbelt.de/en/
    This is one of the products that I saw on the internet. It can generate haptic feedback without sound.
    Any ideas?
