Ask an Expert Forum Reading a Schematic and help understanding what materials needed
  • Replies 13 replies
  • Subscribers 335 subscribers
  • Views 3866 views
See a helpful answer?
Akosha
Akosha over 3 years ago
    shabaz over 3 years ago +4
    This is not a good circuit. It looks like someone's experiment... Clues: It is badly laid out with GND net connections pointing upward (instead of downward towards ground), and messy layout. Also the creator…
  • robogary
    robogary over 3 years ago in reply to Akosha +4
    Avoid this plant in your recording endevours .
  • ggabe
    ggabe over 3 years ago +2
    Akosha , why do you need materials? If you plan to build the circuit, please let us understand your goal, there are much better "things" to build, other this impractical 741 circuit.
  • ggabe
    ggabe over 3 years ago in reply to Akosha
    So by "plant" you really meant a living plant and not the plant in process control. Those signals are rather DC or below 1Hz and in the millivolt range. Sound card will not pick it up, you need a precision low drift low noise DC amplifier with low pass filter. I assume you want something like in this article: https://dacemirror.sci-hub.se/journal-article/529a0faa05eb9b40c5e25b8331ccf9f3/fromm2006.pdf
    dougw over 3 years ago in reply to Akosha
    There might be some signals in the audio range, but there would also likely be DC or very low frequency signals which would not be captured by the audio input on a PC.
  • phoenixcomm
    phoenixcomm over 3 years ago in reply to robogary
     robogary  LOL
