    • Avnet Boards Community
Ask an Expert Forum XIAO nRF52840 free-fall detection not working
  • Replies 15 replies
  • Subscribers 286 subscribers
  • Views 3123 views
  • ardunio
  • interrupts
  • nrf52840
  • free-fall
  • lsm6ds3
See a helpful answer?
TobiasR
TobiasR over 2 years ago
Hello there,
I'm trying to detect free falls with my XIAO nRF52840 which has the LSM6DS3 IMU included.
However, I can't make it work - neither "by polling" not receiving any interrupt for this.
I found some good examples for (Double) Taps with interrupts and it works fine.
But when I adapt the code the free-fall detection I never get anything.
And just to be sure I bought multiple nRF52840 boards but none seems to work. So they are not just broken.
Even the sample code from the libraries doesn't result anything (it compiles, just does not trigger).
I even asked in forums like here
https://forum.arduino.cc/t/lsm6ds3-free-fall-detection-not-working/1163290/7
and
https://forum.seeedstudio.com/t/xiao-nrf52840-free-fall-detection-not-working/272103
Maybe someone here might know more. I saw some good blog posts and smart answers here.
The adapted sample code (also from Sparksfun) looks like that:
#include "LSM6DS3.h"
#include "Wire.h"
#include "SPI.h"
LSM6DS3 myIMU( I2C_MODE, 0x6A );
void setup() {
 Serial.begin(9600);
 while (!Serial) {
 ; // wait for serial port to connect. Needed for native USB port only
 Serial.println("Sketch came out of reset.\n");
 if( myIMU.begin() != 0 )
 Serial.print("Error at begin().\n");
 else
 Serial.print("\nbeginCore() passed.\n");
 uint8_t errorAccumulator = 0;
 uint8_t dataToWrite = 0;
 //Setup the accelerometer******************************
 dataToWrite = 0; //Start Fresh!
 dataToWrite |= LSM6DS3_ACC_GYRO_BW_XL_200Hz;
 dataToWrite |= LSM6DS3_ACC_GYRO_FS_XL_2g;
 dataToWrite |= LSM6DS3_ACC_GYRO_ODR_XL_416Hz;
 // //Now, write the patched together data
 errorAccumulator += myIMU.writeRegister(LSM6DS3_ACC_GYRO_CTRL1_XL, dataToWrite);
 errorAccumulator += myIMU.readRegister(&dataToWrite, LSM6DS3_ACC_GYRO_CTRL4_C);
 // Write 00h into WAKE_UP_DUR
 errorAccumulator += myIMU.writeRegister( LSM6DS3_ACC_GYRO_WAKE_UP_DUR, 0x00 );
 // Set FF threshold (FF_THS[2:0] = 011b)
 // Set six samples event duration (FF_DUR[5:0] = 000110b)
 // Write 33h into FREE_FALL
 errorAccumulator += myIMU.writeRegister(LSM6DS3_ACC_GYRO_FREE_FALL, 0x33);
 // FF interrupt driven to INT1 pin
 // Write 10h into MD1_CFG
 errorAccumulator += myIMU.writeRegister( LSM6DS3_ACC_GYRO_MD1_CFG, 0x10 );
 // Also route to INT2 pin
 errorAccumulator += myIMU.writeRegister( LSM6DS3_ACC_GYRO_MD2_CFG, 0x10 );
 // Latch interrupt
 // Write 01h into TAP_CFG
 errorAccumulator += myIMU.writeRegister(LSM6DS3_ACC_GYRO_TAP_CFG1, 0x01);
 if( errorAccumulator )
 Serial.println("Problem configuring the device.");
 else
 Serial.println("Device O.K.");
void loop()
 uint8_t readDataByte = 0;
 //Read the wake-up source register
 myIMU.readRegister(&readDataByte, LSM6DS3_ACC_GYRO_WAKE_UP_SRC);
 //Mask off the FF_IA bit for free-fall detection
 readDataByte &= 0x20;
 //Check for free-fall
 if( readDataByte )
 //debounce
 delay(10);
 Serial.println("Interrupt caught. Free fall detected.");
And here is also the adapted sample from the double tap (which worked but doesn't when changing tap to free-fall):
#include "Wire.h"
LSM6DS3 myIMU(I2C_MODE, 0x6A);
#define int1Pin PIN_LSM6DS3TR_C_INT1
volatile uint8_t interruptCount = 0; // Amount of received interrupts
uint8_t prevInterruptCount = 0; // Interrupt Counter from last loop
void setup() {
    Serial.begin(9600);
    while (!Serial) {
    Serial.println("--- START ---");
    pinMode(LED_RED, OUTPUT);
    pinMode(LED_GREEN, OUTPUT);
    pinMode(LED_BLUE, OUTPUT);
    setLedRGB(false, false, true); // set blue led
    myIMU.settings.accelEnabled = 1;
    myIMU.settings.tempEnabled = 1;
    myIMU.settings.gyroEnabled = 1; // Gyro currently not used, disabled to save power
    if (myIMU.begin() != 0) {
        Serial.println("IMU error");
    } else {
        Serial.println("IMU OK!");
    setupFreeFallInterrupt();
    pinMode(int1Pin, INPUT);
    attachInterrupt(digitalPinToInterrupt(int1Pin), int1ISR, RISING);
void loop() {
    setLedRGB(false, false, true); // reset led to blue only
    Serial.print("\Iterrupt Counter: ");
    Serial.println(interruptCount);
    // if interrupt was received in this cycle
    if (interruptCount > prevInterruptCount) {
      Serial.println("\Interrupt received!");
      setLedRGB(false, true, false); // set green only
    prevInterruptCount = interruptCount;
    if (interruptCount >= 5) {
      // Trigger System OFF after 5 interrupts
      goToPowerOff();
    myIMU.writeRegister(LSM6DS3_ACC_GYRO_TAP_CFG1, 0x01); // LATCHED
    delay(500);
// -------------------- System ------------------------- //
void goToPowerOff() {
  setLedRGB(false, false, false);
  Serial.println("Going to System OFF");
  setupFreeFallInterrupt(); // not needed here, if already applied..
  delay(100); // delay seems important to apply settings, before going to System OFF
  //Ensure interrupt pin from IMU is set to wake up device
  nrf_gpio_cfg_sense_input(digitalPinToInterrupt(int1Pin), NRF_GPIO_PIN_PULLDOWN, NRF_GPIO_PIN_SENSE_HIGH);
  NRF_POWER->SYSTEMOFF = 1;
// -------------------- Interrupts ------------------------- //
void setupFreeFallInterrupt() {
  uint8_t error = 0;
  // 4A = 01001010
  //      0000 10 10  LSM6DS3_ACC_GYRO_BW_XL_100Hz LSM6DS3_ACC_GYRO_FS_XL_4g
  dataToWrite |= LSM6DS3_ACC_GYRO_BW_XL_100Hz; // 0000 0001  200Hz
  dataToWrite |= LSM6DS3_ACC_GYRO_FS_XL_4g;    // 0000 0000  2g
  dataToWrite |= LSM6DS3_ACC_GYRO_ODR_XL_104Hz;// 0100 0000  104Hz
  error += myIMU.writeRegister(LSM6DS3_ACC_GYRO_CTRL1_XL, dataToWrite);
  // Set the ODR config register to ODR/4  -> 1001
  //error += myIMU.writeRegister(LSM6DS3_ACC_GYRO_CTRL8_XL, 0x09);
  // p.61
  // enable linear acceleration sensor
  //error += myIMU.writeRegister(LSM6DS3_ACC_GYRO_CTRL9_XL, 0x38);
  // Wakeup source (p.62)
  // 00100000 x20
  // 00101111 x2f FF
  error += myIMU.writeRegister(LSM6DS3_ACC_GYRO_WAKE_UP_SRC, 0b00100000);
  // TAP_CFG (58h) Register (page 77)
  // Latch interrupt - Write 01h into TAP_CFG
  error += myIMU.writeRegister(LSM6DS3_ACC_GYRO_TAP_CFG1, 0b00000001); // LATCHED
  //MD1_CFG (5Eh) Functions routing on INT1 register (page 80)
  // Free fall
  error += myIMU.writeRegister(LSM6DS3_ACC_GYRO_MD1_CFG, 0b000010000);   // 00010000
  //p.79 -> default valuesMD1_CFG
  error += myIMU.writeRegister(LSM6DS3_ACC_GYRO_WAKE_UP_DUR, 0b00000000);
  // p.80 ->
  // 00110 : 6 events
  // 011 : 312mg threshold
  //error += myIMU.writeRegister(LSM6DS3_ACC_GYRO_FREE_FALL, 0x33); // 00110 011
  error += myIMU.writeRegister(LSM6DS3_ACC_GYRO_FREE_FALL, 0b000110);    // 00001 011 1x 312mg
  //error += myIMU.writeRegister(LSM6DS3_ACC_GYRO_FREE_FALL, 0x30); // 00110 000   156mg
  //error += myIMU.writeRegister(LSM6DS3_ACC_GYRO_FREE_FALL, 0x00); // 00000 000 156mg
  //error += myIMU.writeRegister(LSM6DS3_ACC_GYRO_FREE_FALL, 0x07); // 00000 111 500mg
  if (error) {
  } else {
void int1ISR()
  interruptCount++;
// -------------------- Utilities ------------------------- //
void setLedRGB(bool red, bool green, bool blue) {
  if (!blue) { digitalWrite(LED_BLUE, HIGH); } else { digitalWrite(LED_BLUE, LOW); }
  if (!green) { digitalWrite(LED_GREEN, HIGH); } else { digitalWrite(LED_GREEN, LOW); }
  if (!red) { digitalWrite(LED_RED, HIGH); } else { digitalWrite(LED_RED, LOW); }
Does anyone have any idea what I'm doing wrong?
  • TobiasR
    TobiasR over 2 years ago +4 verified
    To everyone having the same issue The issue was solved (sadly not by me but guys like you). So for anyone else having this issue you may have a look here forum.seeedstudio.com/.../9 for additional…
  • baldengineer
    baldengineer over 2 years ago +1
    My long-time experience with Seeedstudio is that their examples do not work. In fact, I have received pre-release boards that had broken examples from day 1 that never got fixed! Since the Xiao is really…
  • baldengineer
    0 baldengineer over 2 years ago
    Since the Xiao is really more of a form factor that, in this case, uses the nRF52840, you might look for other Arduino-compatible boards with the same chip. You might find examples in those that help identify what you need to do to get it working.
    Unfortunately, that is the only way I seem ever to be able to use Seeed's hardware: use another vendor's code.
  • colporteur
    0 colporteur over 2 years ago in reply to baldengineer
    That is an unfortunate commentary. It would be frustrating to experience the scenario and have no avenue of support. I hope Seeed's is monitoring. I will think twice before using their product.
  • balajivan1995
    0 balajivan1995 over 2 years ago in reply to baldengineer
    I didn't have much luck with isr routine on esp32 or esp8266 boards when delay functions were added.
  • baldengineer
    0 baldengineer over 2 years ago in reply to balajivan1995
    The ESP Arduino core might block interrupts, but I doubt it. I know it blocks in its own thread which upsets the RTOS. However, ISRs should still be serviced. Other wise, delay() and Serial/USB wouldn't work together--which would break a lot of code.
    For the nRF52 (and other Arm-based implementations), the ArduinoCore-mbed is used.
    void delay(unsigned long ms)
    #ifndef NO_RTOS
      rtos::ThisThread::sleep_for(ms * 1ms);
    #else
      wait_us(ms * 1000);
    #endif
    My understanding is that the either with or without the RTOS, the mbed implementation will block the thread (as expected) but still service interrupts.
    And, on the 8-bit/AVR Arduino-cores, interrupts are purposely serviced during delay().
  • TobiasR
    +1 TobiasR over 2 years ago
    for additional info.
    But in short: you need to enable the TIMER_EN flag in the TAP_CFG register.
    I added a pull request in the sample code of seeedstudio. Once this is accepted the examples from their website should work again!
    Thanks to everyone for your support!
