Ask an Expert Forum Want to measure frequency response of speaker
  • Replies 11 replies
  • Subscribers 333 subscribers
  • Views 7309 views
  • audio
  • audio amplifier
  • audio_engineering
See a helpful answer?
manojroy123
manojroy123 over 3 years ago
I was looking online to measure frequency response of a speaker. Most of the technique they provide is to place a microphone in front of the speaker to measure frequency response of the speaker. I find it to be inaccurate with large amount of unidentified error. I came up with the idea and have shown it in image bellow. I would like to know is my concept good enough to give me accurate frequency response of speaker than traditional technique.
If there is problem in the concept please let me know how to solve it.
    michaelkellett over 3 years ago +4
    The best way to measure the frequency response of a loudspeaker is with a small (12mm diameter or less) high quality capacitor microphone. This directly measures the sound produced by the speaker. …
  • scottiebabe
    scottiebabe over 3 years ago +3
    You can also take a look at app notes measuring TS speaker parameters for inspiration sbacoustics.com/.../Measuring-Thiele-Small-parameters.pdf
  • saadtiwana_int
    saadtiwana_int over 3 years ago +2
    The main concern I have is that your speaker is producing Audio waves, while your inductor would be picking up changes in magnetic field going through it. So I don't think it's the best setup for measuring…
    0 dougw over 3 years ago in reply to manojroy123
    Perhaps you could use a Hall effect sensor so the magnetic field is not affected as much by the sensor, but the magnetic field will not indicate precisely how the speaker cone translates magnetic field into pressure waves in air. The shape of he cone, its material stiffness, its mass, its mounting geometry, the mounting materials, the surrounding material properties of absorbing and reflecting pressure waves etc. all affect the sound. Even bouncing a laser off the speaker cone doesn't provide a full picture of the sound generated.
    So far, microphones and all their distortions are about the best way for an instrument to monitor sound.
