Ask an Expert Forum Question on how to energize a air transducer
  • Replies 13 replies
  • Subscribers 333 subscribers
  • Views 2633 views
See a helpful answer?
Ed2024
Ed2024 over 2 years ago
Looking at energizing 72 200KHz Air Transducers for a science experiment. Only need to send a signal not trying to receive it back also wondering if you can piggy back a second signal on the 200KHz air transducer.  Need a generator that will work for the transducers to work.
  What are the power requirements for the 200KHz air transducer. Your help would be appreciated, Ed
    michaelkellett over 2 years ago in reply to Ed2024 +3
    I am confident that you will not be ignored if you can demonstrate anti-gravity. I am equally confident that you will not do so. Levitation using acoustics has been demonstrated but is no more anti…
  • Andrew J
    Andrew J over 2 years ago in reply to anniel747 +2
    I can't tell from here, but that screw looks wrong - should be Pozidrive. Will never work with that one.
  • anniel747
    anniel747 over 2 years ago in reply to michaelkellett +1
    Deleted
  • anniel747
    0 anniel747 over 2 years ago in reply to michaelkellett
    [deleted]
    0 michaelkellett over 2 years ago in reply to anniel747
    $36 - that's pretty much free in some circles. Its a long time since I bought a Bruel and Kjaer Accelerometer but when were were selling them literally by the million as knock sensors at about £3 each a B&K part was £200 - 300. Much better than our knock sensor but very similar inside. Theirs cam in a little box (wooden in the 70s but changed to plastic later) and with a cal certificate.
    I designed a tank level measuring system for a customer a long time ago and I researched (but didn't use) some 200kHz transducers. I'll have  a look later and see if I can find an more data and a picture of what's inside.
  • beacon_dave
    0 beacon_dave over 2 years ago in reply to michaelkellett
    michaelkellett said:
    The 60dB or more difference between the TX and RX signal causes problems. There is always a minimum measurable distance because you need to allow things to calm down a bit in sensor and electronics before you can detect an echo signal.
    As others appear to have found out...
    https://e2e.ti.com/support/sensors-group/sensors/f/sensors-forum/614398/pga460-q1-issues-while-using-200khz-transducer
