Ask an Expert Forum Reading Component Datasheets!
  • Replies 15 replies
  • Subscribers 335 subscribers
  • Views 1365 views
  • students
  • hobbyists
  • datasheets
  • new-engineers
See a helpful answer?
cespecialist
cespecialist 9 months ago
I’m planning a practical post on how to interpret component datasheets for real designs—what the different parameters and graphs are actually telling you.
Before I start, I’d like to get some feedback: would this be useful to the community?
  • colporteur
    colporteur 9 months ago +2
    Some twenty years ago, I worked with a electronic technician that made data sheets his bathroom read. I'm not sure if did it at home but I work, he would head off to the commode with a supplier tomb of…
    dougw 9 months ago +2
    Definitely a useful initiative. Very involved though - might want to tackle it with multiple posts covering specialized subsets like op-amps or transistors.
    michaelkellett 9 months ago +1
    This sounds like a very ambitious project - if it was as well done as "The Art of Electronics" it could be useful. But that would require a great deal of knowledge and experience, as well as time and…
  • cespecialist
    cespecialist 9 months ago in reply to acdc90
    Thank you for your feedback.  One of the goals of this initiative is to highlight why “equivalent parts” sometimes fail in real circuits, and how looking beyond headline datasheet specs becomes critical when selecting or replacing devices.
    Jan Cumps 9 months ago in reply to cespecialist
    That would mean that your work would be adding to the datasheets, if I understand the meaning of "beyond" correctly.
    What type of info are you adding to make the selection of equivalent parts easier?
  • dang74
    dang74 9 months ago in reply to colporteur
    Very interesting story.  Sounds like this guy lived and breathed datashhets.  Hard to know in the end if he had super mental powers or just a super laser focused interest.  Either way, it's very impressive.
  • dang74
    dang74 9 months ago in reply to Jan Cumps
    I could see a guide being divided into different chapters according to component type such as opamps, comparators, diodes, transistors etc.  The last two items probably further divided into sub-groups.... and then in the section for general purpose diodes, for example, describe the key specs like reverse break down voltage and forward current and why each is important.  For reverse break down voltage you can go into an example where a diode is used in a rectifier.... anyway... that's how envision this.
  • cespecialist
    cespecialist 9 months ago in reply to Jan Cumps
    Good question.  I am not looking to add any information beyond what's already in the datasheets, but to show how to interpret the parameters.  A simple example is 1N4007 and UF4007.  Both are rated for 1000V, 1A and are available DO-204(AL) package.  These are not alternate parts as the reverse recovery times are different. The difference is already available in the datasheet, but can be easily missed if we just look at 1000V, 1A and DO-204(AL) package.
