Ask an Expert Forum How to determine the health state of a LiPo battery?
  • Replies 16 replies
  • Subscribers 336 subscribers
  • Views 774 views
  • battery
See a helpful answer?
obones
obones 1 month ago
I have taken out those two batteries from a device that needs both.
Clearly, the one on the right is dead and needs replacing.
However, I'm wondering about the state of the one on the left as it was manufactured at the same time.
Considering how expensive it is to come by the same model in France, I'd rather avoid buying two when one would be enough.
Here, I have a bench power supply, a bench DMM, an oscilloscope, a few ESP32s or arduino, even a RedPitaya but I doubt this one would be of any help here without specialized apparatus.
Many thanks for any suggestion.
    michaelkellett 1 month ago +3 suggested
    A full charge and discharge cycle is the only way to know for sure how good a LiPo is. A visual inspection first will save you time and danger, get rid of the bloated one ! To do the measuring properly…
    michaelkellett 1 month ago in reply to obones +2
    You can buy a similar rated LiPo battery from Amazon for about £10. It won't have the third (white) wire. According to Google AI the third wire will be for a thermistor. You can check this on the two batteries…
    shabaz 1 month ago +1
    Hi, If the unloaded terminal voltage (i.e. just apply multimeter to the terminals with the battery disconnected from the equipment) is lower than about 3.0V, then it's likely a risk to use it, some damage…
  • obones
    0 obones 1 month ago in reply to geralds
    Yes, that kind of price is what I found as well. But one must be very careful, most stocks in that price range are outside the European Union and thus incur a very real risk of additional taxes upon receipt.
    And I made the same conclusion as you, there is no point in investing in testing equipment just for a one off. If it had been doable with gear I already own, it would have been easier.
  • geralds
    0 geralds 1 month ago in reply to obones
    ....measuring under defined load and calculation using the datasheets.
    That is what you can.
    Here in 2004 there was a DY project:
    https://de.elv.com/p/lipo-die-neue-akku-generation-P201134/?itemId=201134
    https://de.elv.com/p/lipo-die-neue-akku-generation-P201134/?itemId=201134&utm_campaign=affiliate_exitintend_de
  • obones
    As I'm on the subject, would transferring the existing management board to a brand new battery would be worth considering?
    This would have the advantage of keeping the connector and the thermistor connection, but I'm not sure how safe/easy it is to do so.
    Note: the replacement is already ordered, this is more of a "just in case" follow up question
  • obones
    0 obones 1 month ago in reply to michaelkellett
    I gently removed the kapton tape around the BMS and was able to take what I think is an interesting picture:
    To me it looks like the white wire is tied to ground, effectively making thermal management a joke because the NTC thermistor simply is not there!
    Do you make the same conclusion here?
    0 michaelkellett 1 month ago in reply to obones
    I do !
    Are there any other bits on the little board ?
  • obones
    Not on that side, the components are on the other one:
    The three big ones appear to have the same 8205A marking, consistent with TSSOP8 mosfet
