Passive Components
Passive Components
Forum Need SOLDERING (non PCB) Projects Using This 6-pin HKE Relay, Preferably an Automatic Light With an Ldr.
Join Passive Components to participate - click to join for free!
  • Replies 12 replies
  • Subscribers 106 subscribers
  • Views 3974 views
  • 6-pin
  • diy
  • soldering
  • relay
Pinto_Marcelo
Pinto_Marcelo over 3 years ago
Hello world, I'm new here, and I tried to search for some projects with this Relay but I couldn't find it.
I would love to solder circuits WITHOUT PCB, like this: www.youtube.com/.../Rm68zeCjxLg
preferably an automatic light with an ldr.
I've been studying this datasheet, but it doesn't work like other relays...
Thank you!
As you can see, this 6-pin relay has no diagram.
And these pins I soldered trying to do a test.
  • baldengineer
    baldengineer over 3 years ago in reply to anniel747 +2
    Because OP is holding a 6-pin device and the other diagram is a 5-pin device.
  • anniel747
    anniel747 over 3 years ago +1
    Deleted
  • Pinto_Marcelo
    Pinto_Marcelo over 3 years ago in reply to anniel747 +1
    https://www.alldatasheet.com/datasheet-pdf/pdf/1572441/ETC/HK4100F-DC12V.html community.element14.com/.../HK4100F.PDF
  • baldengineer
    baldengineer over 3 years ago in reply to Pinto_Marcelo
    What are you using to power the coil?
  • robogary
    robogary over 3 years ago
    The relay does have a diagram and spec sheet. The pinout is just a bit different than other common relays.
