Power & Energy
Power & Energy
Forum Trickle charging a button cell battery using an energy harvester?
  • Replies 11 replies
  • Subscribers 284 subscribers
  • Views 2881 views
  • dc-dc
  • batteries
  • power_management
  • battery
  • power_supply
  • power_conversion
Hey all from Element 14! My name is Elliott Leinauer and im a highschool student working on a science fair project. My project encompasses using very low voltage and current and harvesting it to create more voltage to power a high lumen led light! To make somthing like a flashlight. My problem as of right now is trying to store this harvested energy. My harvested energy is supplying me anywhere from .700-1.5v depending on conditions. With roughly .15-.20mA. Im curious to know if its possible to somehow trickle charge a 3.5v lets say 120mah button cell battery in order to give my led light constant power so it stays nice and bright over a long duration of time. Is it possible to do this with the current I have? If so can anyone point me in the right direction as to which button cell battery I should buy?
Keep in mind im realtivley unexpericend with circuitry,  I was  thinking  to raise my current without loosing to much voltage  I could somehow incoperate a transistor in the circuit before the power is directed to the button cell. Is this atall possible or am I just talking nonsense?
Thanks!!
    0 jw0752 over 10 years ago in reply to Former Member
    Hi Elliott,
    I agree the michaelkellett  about the board you have listed. I  am curious how you are arriving at your stated 3.3 volts with 40 mA from your energy harvester. Are these published numbers or are you actually measuring these values as the harvester works into a load? It would be fun to see some diagrams and pictures of your project.
