Power & Energy
Power & Energy
Forum What is the best way to learn how to design and make SMPS transformers?
  • Replies 17 replies
  • Answers 2 answers
  • Subscribers 284 subscribers
  • Views 4647 views
  • smps
  • transformer
peterjcs23
peterjcs23 over 11 years ago
I'd like to learn about designing and making transformers for switch mode power supplies. For example if we start with an AC to isolated DC supply say 240Vac to 5V dc 1A. Is there an evaluation kit to buy? Is there a good tutorial anywhere that you have found useful? I don't want to buy a transformer I want to choose the right core and winding and understand the principles. And there are different configuration for the control circuit, I'd like to understand that too. But to begin with a simple intro scheme will do. Thanks, Peter.
  • clem57
    clem57 over 11 years ago +1 suggested
    Designing Switchmode Transformers for Optimum Efficiency | Content content from Power Electronics starting point with What is an SMPS | Switch Mode Power Supply Tutorial | Radio-Electronics.com tutorial…
    michaelkellett over 11 years ago +1
    I don't know if there is some material on the web (I expect that there is) but I once attended a very good TI seminar about power supplies with a very good lecture on transformer/inductor design. MK
  • kkazem
    kkazem over 11 years ago in reply to peterjcs23 +1 suggested
    Peter, Unless you need that evaluation kit for the electronic converter, I'd say away from it as It looks like it has a ready-made transformer in it. If you want to design and build your own transformer…
    Yeah, transductors is wrong name for this type of thing! Transformer is ok and I have also heard about 'flyback transformers'. but why won't you just buy such a thing intstead of making it yourself?
  • D_Hersey
    0 D_Hersey over 11 years ago
    There are a many good books on transductor design  or ones that have chapters on the topic.  Core manufactures have some pretty neat calculators on their websites.  While you are there you can read about the various (MPP, Sendust, etc.) mixes, core (toroid, E, etc.) geometries, and just as important, insulation schemes for different potential and power regimes.  Not to mention conductor choices such as Litz wire, square wire, etc.
    The motivation behind a custom core is custom windings.  It would be very difficult for anyone to source a spectrum of transductors 'cause it takes two-three parameters to characterise them (imaginary terms)  Resistors have one-two terms and I have a literal wall of them.  Not to mention n secondary windings.
    The industry is set up to wind you a few good cores on the cheap if you look around.
    https://www.cwsbytemark.com/
    Fair-Rite Products Corp. | Ferrite | Ferrite Components | Ferrites | Inductive Materials | Suppression Materials | Magne…
  • D_Hersey
    Yeah, Transductor is a common term of art these days.  I suggest reading.
    All cores have more and more air in them as frequencies increase.  The soft-saturating characteristics of MPP are due to the properties of the material as well as the mix and binder.
    To repeat, regular transformers such as ones in regular linear power supplies, or audio coupling transformers have their outputs in phase with the input.  Flyback transformers, or what archaic term of art or label you choose to employ, have their output occur 180 degrees out-of-phase.  There is no other way to say it.  If this isn't seeming to be significant to you, I see no avenue to enlighten.
    While you are reading you can read about modern second-order supplies such as SEPIC and Cuk.  These have outputs between 0 and 180 degrees.
  • D_Hersey
    When designing with a regular in-phase transformer,  we certainly know we have to avoid saturation, but can rule it out pretty easily by properly scaling the device.  Presuming we have chosen one for the right frequency, we are down to an impedance match-up, and we can lump all of the parasitics on the secondary onto the primary.
    In SMPS, there is this event of a power switch being turned on.  Avoiding saturation becomes central to the game.  The nature of the math is different in the two regimes.  There is no Tnought in the world of linear transformers.
  • D_Hersey
    Right now, I am listening to WZRD rf transmission.  Here is an ideal case of a pure transformer;  the antenna of the station is the primary, the core ('air doesn't saturate') is air, and the secondary is the antenna of my stereo.  The wave form is presumed to be composed of finite Fourier terms.  Neglecting (phase) dimensionality.
    In the flyback topology power supply, there is always a core of Fe.  This is where the transformer analogy breaks down.  Where is your air-core SMPS reactor?  The device is charged when S1 is on while S2 is off.  The next phase finds S1 off and S2 on the core discharges.  The wave form is an exponential sawtooth.  The material properties and the capacitive parasitics and couplings (and resistance of) in the conductors are what matter.  We are looking at the core as an inductor + turns ratio and phase signum.
    T
    0 michaelkellett over 11 years ago in reply to D_Hersey
    The first three hits on Google disagree with you - the transductor is classically used to describe a different device altogether. I got bored looking though the Google hits before I found a flyback transformer described as a transductor (sticking with hits in English  - I didn't try to translate the Spanish ones.)
    The definition on Wiki seems to be quite widely accepted:
    Transductor - Wikipedia, the free encyclopedia
    So I'm going with Flyback Transformer - good descriptive name - works for me.
  • mike_91
    0 mike_91 over 10 years ago
    http://accessengineeringlibrary.com/browse/switchmode-power-supply-handbook-third-edition
    This is an incredibly comprehensive text. Highly recommended for beginners and pros alike.
