Sensors
Sensors
Sensor Forum Doable?!
  • Replies 13 replies
  • Subscribers 354 subscribers
  • Views 2211 views
Doable?!
I am just getting into the Raspberry Pi scene so forgive my ignorance - how difficult would it be to write code that could take a distance measure (maxSonar) in mm and convert it to volume (ounces remaining). I have this hairbrained idea to try and monitor fluid levels in my beer keg or hot liquor tank. Yes I am aware of flow meters - just have the sonar on hand from a friend that I can use. Any suggestions would be greatly appreciated.
-Tad
  • xever
    xever over 11 years ago +1
    It appears your range finder has a 4-20mA output, in which case you will require an ADC input to measure the distance and then eventually resolve that into volumetric measurement. The rPi does not have…
    dougw over 11 years ago +1
    RaspberryPi may be a bit of overkill for this application - perhaps an arduino would be simpler... Using a MaxSonar With an Arduino Arduino Playground - MaxSonar
    e14 Contributor over 11 years ago in reply to e14 Contributor
    Thanks for the info Theo Ams. I picked up an Arduino and a neoPixel strip. instead of getting all crazy with formulas and math I decided for now that I wanted to keep it simple. I've got the distance reading correctly and setting up if/then for ranges to correlate with the 8 pixel like a gas tank meter. Eventually I would like to have that info tracked online...
    Your welcome, have fun with your project.image
  • maxbotixinc.
    maxbotixinc. over 11 years ago
    Hello, this is Cody from MaxBotix Inc. I’m glad to support you.
    I believe we have been in direct email contact regarding this topic. However, if you have any more questions about interfacing with our sensors, sensor selection, or general sensor usage please feel free to contact us directly at MaxBotix.
    We are more than happy to assist you!
