Sensors
Sensors
Sensor Forum Detection sensor for tungsten wires
  • Replies 13 replies
  • Subscribers 347 subscribers
  • Views 3764 views
  • sensor
bijoythomaschandy
bijoythomaschandy over 4 years ago
Hi Guys, Any ideas on what sensor to get to detect the presence/absence of a tungsten wire with a diameter of 0.5mm?
  • Workshopshed
    Workshopshed over 4 years ago +2
    You could apply a large voltage and current to it, if there is a tungsten wire then it will glow. But not for long.
    dougw over 3 years ago in reply to bijoythomaschandy +2
    A non-contact metal detector doesn't induce hazardous voltages. But what about feeding it through a ferrule that optically detects when no wire is in the hole?
    shabaz over 4 years ago +1
    Hi, As you no doubt know, your question has insufficient information, and zero context. You might need to give that some thought and then come back with the detail if you wish. Placing this here not…
  • heinej
    heinej over 3 years ago
    How about a presence detection Hall Effect Proximity (reflective) sensor switch?
  • bijoythomaschandy
    bijoythomaschandy over 3 years ago in reply to dougw
    Thanks dougw. Will give that a try.
  • Workshopshed
    Workshopshed over 3 years ago in reply to bijoythomaschandy
    Alternative approaches:
    Weight sensor on the spool so you know when it is depleted.
    Some kind of counter / logic so you can estimate when the spool is getting low.
