Sensors
Sensors
Sensor Forum Sensor Network
  • Replies 18 replies
  • Subscribers 345 subscribers
  • Views 3355 views
  • rs485hub
  • mqtt
  • 4g
  • rs485
  • mosquitto
Sensor Network
corel_draw
corel_draw over 2 years ago
I am a newbie to the sensor network world. Any advice would be well appreciated.
My sensor has rs485 connector. So I want to relay my sensor  data  over 4g iot gateway  to my mqtt broker (mosquitto) and then to cloud.
I intend to use an rs485 hub to collect sensor readings from multiple sensors.
The pipeline in summary sensor ===> rs485 hub ====> iot 4g gateway =====> broker (mosquitto) =====> cloud
/ My question is:
1) I saw modules called rs485 data logger , are those modules needed in this set up ?
2) are there any other considerations for robsutness of this set up
Links to references hardware :
a) rs484 hub: https://www.alibaba.com/product-detail/PINWEI-Industrial-RS-485-HUB-1_1600879469226.html?spm=a2700.galleryofferlist.p_offer.d_title.7eda43a6OXiLmr&s=p
b) iot 4g gateway: https://www.alibaba.com/product-detail/Ebyte-ODM-E840-DTU-EC05-485_1601113842515.html?spm=a2700.wholesale.you_may_like.1.50a23027Z2gCtw
Please kindly advice, and this is my first post so if I am breaking any of community rules so let me know so I can adjust accordingly.
Thank you!
  • kmikemoo
    kmikemoo over 2 years ago in reply to corel_draw +2
    corel_draw Please forgive me if I start out too basic. I started learning this stuff by researching MODBUS RTU. MODBUS and RS485 are not the same. My simple approach may offend some, but... crawl, walk…
  • aswinvenu
    aswinvenu over 2 years ago +1
    The IOT 4g gateway already has an RS485 interface, Why do you want to use another RS485 hub? I think all what you want can be done using https://www.cdebyte.com/products/E840-DTU(EC05-485)E You may have…
  • corel_draw
    corel_draw over 2 years ago in reply to Robert Peter Oakes +1
    Thank you, I needed the hub in case I have multiple sensors ... It is not an essential component of the architecture I agree.
  • colporteur
    0 colporteur over 2 years ago in reply to kmikemoo
    EXCELLENT! Great high level intro  kmikemoo  .
    Terminating the end with a resistor is a valuable tip. I recall first learning about scsi. The instructor had this complicated description of terminations. I spent almost a lifetime in RF. Understanding that you are terminating the end of a transmission line to eliminate reflections, caused his complicated description to disappear.
    I'm curious about your 120 ohm value. I've used 600, 50 and 75. 120 is a new one on me.
  • kmikemoo
    0 kmikemoo over 2 years ago in reply to colporteur
     colporteur I have no idea where the value came from - but we also use it for CAN.  In  teaching basic CAN or RS485 troubleshooting - with the system powered down - check the resistance between A and B.  It should be 60 ohms.  120 ohms from the Master (in most cases but not all) and 120 ohms at the furthest point of the network/cable run.  NO star topography.  Those little branches can become stub attenuators. Laughing
  • colporteur
    I never played in that space so the values would seem foreign to me. As soon as you mentioned transmission you brought back knowledge gained 30 years ago. Thanks for the trip down memory lane.
  • colporteur
    0 colporteur over 2 years ago in reply to colporteur
    https://kvaser.com/developer-blog/how-to-test-your-can-termination-works-correctly/#:~:text=It%20is%20well%20known%2C%20in,each%20end%20of%20the%20bus.
    I found this on quick search of CAN network termination. Wow at 63 I learned something new. Now if I could only remember it:)
  • kmikemoo
    colporteur I didn't understand the problems with star topography until I got into Amateur Radio about 6 years ago.  Now it all makes sense.
    It's not surprising that you found Kvaser.  They make many of the CAN readers/programmers used around the world.  I've used their stuff on German, Swedish, Japanese, Italian and American equipment.  They like customizing their stuff for the different OEMs.  We have 3 readers that look exactly alike but will only work on their respective engine lines.
  • anniel747
    0 anniel747 over 2 years ago in reply to kmikemoo
    CAN-B (83.3 Kbps fault tolerant) and CAN-C (500 Kbps) both have 120Ω dominant node termination. CAN-D has 60Ω. Recessive nodes have 3kΩ terminations.
  • corel_draw
    0 corel_draw over 2 years ago in reply to kmikemoo
    Thank you for the input! I did more research into MODBUS RTU and it was helpful.  Similarly, I appreciate of the start small approach (craw-walk-run) and I will take note of that. Similarly, the pipeline, Gateway -> Device -> Device was helpful in seeing the bigger picture!
    It also turns I linked the wrong device (the actual device was an industrial version of iot gateway in the original question).
    I appreciate the detailed response.
  • phoenixcomm
    0 phoenixcomm over 2 years ago
     corel_draw  Forgive me but kmikemoo is right. why hang yourself with 488?? there are better things in the world like IP (ethernet)  where all you need is a small protocol converter, easy peasy!! Even I despise serial networks that have no information other than their values?? In my Aircraft, I use CANareospace, which is based on the ISO model, so it starts out with a sensor(s), go to a microcontroller to do the sensors, and cat out the other could be a 2-wire network (CAN) or over Ethernet.  ~~ Cris H.
