Sensors
Sensors
Documents Sensors for Pi and Arduino Wishlist
  • Author Author: dychen
  • Date Created: 14 Jun 2022 4:46 PM Date Created
  • Last Updated Last Updated: 1 Apr 2023 2:04 PM
  • Views 74993 views
  • Comments 23 comments
In honor of the Summer of Sensors, we've decided to put together a wishlist of sensors and sensor shields/hats that you can incorporate into your Raspberry Pi and Arduino projects.
Shields and Hats for Raspberry Pi and Arduino
Sensors Kit For Raspberry Pi B+/2/3
This kit for Pi helps beginners get their feet wet with Pi development. Included are a PIR sensor, LDR/photoresistor, and temperature sensor, along with various LEDs, buzzer, and button to make testing easy.
Raspberry Pi Sensors Development Kit
 Buy Now
Raspberry Pi Sense HAT with Orientation, Pressure, Humidity and Temperature Sensors
The Pi Sense HAT gives you access to a variety of sensors, including gyroscope, accelerometer, magnetometer, barometer, temperature, and relative humidity sensor. A built-in LED matrix display and 5 button joystick gives you a simple but effective user interface.
Pi Sense HAT
Buy Now
EKG/EMG Shield for Arduino
Turn your Arduino into a health and medical application. This EKG/EMG Shield lets you experiment with biofeedback, monitoring pulse, and analyzing muscle activity.
EKG/EMG Shield
Buy Now
Arduino Sensor Evaluation Board
Omron's Sensor Evaluation Board gives you access to 6 common types of sensing (temperature, humidity, light, barometric pressure, noise, and acceleration), and connects directly to an Arduino for quick development.
Buy Now
Dust Sensor Development Board
For projects that must survive harsh condition, this humidity and temperature probe is IP67 rated, meaning total protection from dust and immersion in up to 1 meter of water. Perfect for devices that sit outdoors.
Dust Sensor
Buy Now
3-Axis Digital Accelerometer Development Board
The 3-axis digital accelerometer development board connects directly to an Arduino R3, or to Freescale Freedom development boards. Download the Sensor Toolbox software, and get started!
Digital Accelerometer Shield
Buy Now
Sensors
Ultrasonic Distance Sensor
For projects that move autonomously, distance sensors are required. This ultrasonic ranging sensor lets your robot sense objects up to 4m away.
Ultrasonic sensor
Buy Now
Temperature Sensor
Temperature sensors help monitor not only climate and environment, but overheating machinery. This sensor works with both Pi and Arduino, and keeps a watchful eye on thermal conditions.
Temperature Sensor
Buy Now
Tilt Sensor
Tilt sensors measure orientation or inclination. They're useful in many applications, including robotics, vehicles, and factory automation.
Tilt/Shift Sensor
Buy Now
37-piece Sensor Set
If you want a variety of sensors that cover almost everything, DFRobot provides a 37-piece kit that contains a wide variety of sensors, including sound, heart rate, color, acceleration, vibration, gas, pressure, and more. Compatible with DFRobot's Gravity system. Each sensor is also available individually.
DFRobot 37 piece sensor kit
Buy Now
AmbiMate Development Kits
AmbiMate
TE Connectivity's AmbiMate development kits connect to Raspberry Pi or Arduino, and with some downloadable code, let you start collecting data immediately. Several application specific kits are available.
Audio, Humidity, Light, Motion, Temperature
 Buy Now
 Buy Now
CO2, Humidity, Light, Motion, Temperature
 Buy Now
  • sensors
  • raspberry pi
  • summer of sensors
  • misaz
    misaz over 4 years ago in reply to beacon_dave +2
    I have used Vishay device from this family and they are realy nice.
    beacon_dave over 4 years ago in reply to RickRoy +1
    The Vishay TSOP devices are popular for this: https://thepihut.com/products/ir-sensor They come in different carrier frequencies, that is a 38kHz one as indicated by the last two digits (TSOP58238…
  • RickRoy
    RickRoy over 4 years ago in reply to beacon_dave +1
    Thanks for the info, that's awesome! I have a couple of remotes from TVs that went to TV Heaven long ago. I could certainly use one of them for my Arduino projects. If I could consistently differentiate…
    beacon_dave over 4 years ago in reply to beacon_dave
    The sketches are available for download:
    https://www.elektor.com/mastering-microcontrollers-helped-by-arduino-3rd-edition#downloads
    Sketches Chapter 1-10.zip
    Chapter 09 - The Clock Is Ticking
    • decode_nec_ir_rc_protocol
    • export_ir_pulses_to_svg_file
    • guess_ir_format
    The TSOP IR device is discussed in this Arduino programming book:
    Shows you how to capture, identify and decode a signal from an IR remote.
    Also demonstrates how to use SVG graphics mark-up to display the captured IR timing waveform.
  • RickRoy
    Thanks for the info, that's awesome! I have a couple of remotes from TVs that went to TV Heaven long ago. I could certainly use one of them for my Arduino projects. If I could consistently differentiate between just a few buttons on the remote, that would be way better (IMO) than hard-wiring buttons to the Arduino! If I got a little fancier with reading the signals, I would even be able to enter numeric data.
  • misaz
    They come in different carrier frequencies, that is a 38kHz one as indicated by the last two digits (TSOP58238).
    You will need to work out what protocol the remote uses in order to decode the received signal as they tend to vary between manufacturers.
  • RickRoy
    I want a sensor that can detect the IR signals from my TV remotes. Then I can use a TV remote as the user interface to control my Arduino project.
  • Gough Lui
    Gough Lui over 4 years ago
    I always like building environmental sensor units ... for that, usually I choose the Bosch BME680 (which made the list), but also usually I incorporate the Sensirion SPS30 particulate monitor sensor and SGP30 (CO2eq, VOC) sensor as well. That being said, I think the SGP30 would probably be replaced by a proper IR-based CO2 sensor, perhaps something like an SCD30, but I haven't had the chance to explore that myself. Nice to see the Omron stuff made the list too - I've been using those since the RoadTest and they haven't skipped a beat!
    - Gough
  • Vimal_g
    Vimal_g over 4 years ago
    • Water level sensor and Flame sensor should also be included.
    dougw over 4 years ago
    There are some interesting sensors I would like to see in Arduino shields for MKR or Nano MCUs:
    • VL53L0X LASER Range Sensor to accurately measure distance up to 2 m
    • Novelda Ultra-Wideband (UWB) radar sensing to detect human presence among other applications
    • Microwave Doppler X-Band Radar Sensor to detect motion at 20 m
    • a load cell interface (excitation and signal conditioning for 2 Wheatstone bridge load cells)
    Some other cool sensors that are missing are
    • a (magnetic) angle sensor
    • other Hall effect sensors
    • Sharp IR distance sensors
    • fiber optic transmitter/receiver (the receiver is a sensor)
    • LIDAR sensor
  • c4m4ch01
    c4m4ch01 over 4 years ago
    I would create one with environmental sensors but would include the AS3935 sensor for thunderstorm detection. Maybe the usage wouldn't be very high during the year (at least where I live, it only thunders once or twice a year), but when it does it would be exciting to see the thunder data (if there isn't a power outage, it is clear).
