Sensors
Sensors
Quiz Strain Gauges Quiz
  • Author Author: pchan
  • Date Created: 8 Aug 2022 5:41 PM Date Created
  • Last Updated Last Updated: 4 Jun 2024 7:46 PM
  • Views 17459 views
  • Likes 16 likes
  • Comments 69 comments
Strain Gauges Quiz
Strain gauges are used to measure strain in several applications, including aerospace, transportation, industrial and more. Test your knowledge with our quiz on strain gauges.
profile image
sponsored by sponsor logo
Quiz | Sensors | Industrial Automation | Resource | Transportation & Automotive
Strain Gauges Quiz
Strain Gauges Quiz Score 100% on our Strain Gauges Quiz and leave your feedback as a comment to earn this badge...
To earn the Strain Gauges Badge, score 100% on the quiz and leave your feedback on the quiz as a comment.
  • e14quiz
  • omega
  • strain gauges
  • maxpowerr
    maxpowerr over 4 years ago +1
    Is it possible to make a water level indicator on Strain gauges?
  • ralphjy
    ralphjy over 4 years ago +1
    Another informative quiz. I really haven't used strain gauges in any of my projects, so far...
  • navadeepganeshu
    navadeepganeshu over 4 years ago +1
    Interesting quiz! Is there a document to read through before attending this quiz? Used to see in earlier quizes,...
  • phoenixcomm
    phoenixcomm over 4 years ago in reply to maxpowerr
    yes but why bother, capacitive sensor is the way to go. basically, one tube larger than your center rod then shim the rod to be in the center of the tube drill wholes all over the larger tube to let the water in out, connect to a wine bridge, and away you go.
    here's a nice little DIY thing Capacitive-Fluid-Level-Sensor and BTW If you know how much your container holds you can easily calculate the weight of the water.
    1. the US contains are in gallons. convert it liters = 1 gal = 1 liter = 1Kg (3.78541L per Gal ) or about 3.785 Kg /per Gal.
    2 calibrate the sensor, get some 5-gallon pails of water (make sure your sensor is a few inches off the bottom. start empty and start pouring in the buckets.
    3 have some fun.
  • Gough Lui
    Gough Lui over 4 years ago in reply to phoenixcomm
    Sorry- it's none of those you listed in your copy of the question - but it is indeed Lord Kelvin as per this ScienceDirect book chapter excerpt (https://www.sciencedirect.com/topics/earth-and-planetary-sciences/strain-gage):
    The question is not asking who invented the strain gage ... but merely who, in 1856, discovered the effect ...
  • phoenixcomm
    interesting?? but
    PROBLEM #6
    • 6) In 1856, ________ reported that metallic conductors show a change in electrical resistance when they are subjected to mechanical stress.
      1. Thomas Edison
      2. Marie Curie
      3. Nikola Tesla
      4. None of the Above
      should be NONE OF THE ABOVE: A strain gauge (also spelled strain gage) is a device used to measure strain on an object. Invented by Edward E. Simmons and Arthur C. Ruge in 1938, -- Wiki
  • Gough Lui
    Took two attempts, but got there in the end.
    dougw over 4 years ago in reply to Ziya
    Look for an HX711 module...
    https://www.arduino.cc/reference/en/libraries/hx711-arduino-library/
    https://www.youtube.com/watch?v=sxzoAGf1kOo
    dougw over 4 years ago in reply to beacon_dave
    That type of strain gage doesn't need electronics to indicate failure...Skull
  • Ziya
    Ziya over 4 years ago
    Is there any strain gauge sensor for arduino?
  • misaz
    misaz over 4 years ago
    Good and informative quiz. Nice to meet this type of sensors.
  • swalberg
    swalberg over 4 years ago
    Didn't realize how much there was to this!
    beacon_dave over 4 years ago
    Always a bit worrying when you see the crack running through the centre of a strain gauge as well as the wall it is attached to. Fearful
