Arduino Forum Arduino
  • Replies 8 replies
  • Answers 3 answers
  • Subscribers 407 subscribers
  • Views 861 views
  • frontpage
kushali
kushali over 8 years ago
I would like to get an arduino code for the following requirements
The system should monitor the temperature of the room.
 Light different LEDs depending on the temperature
 Sound an alarm if it is too hot.
 Activate a fan through a transistor to cool the system down if it gets above a certain temperature.
 Use different fan speeds depending on the temperature by pulsing the fan.
 Implement an alarm reset system using a code sequence from button presses.
 It should only work when the lights are on, using an LDR.
 Use a potentiometer as a calibration mechanism.
 Print out an array of information on request of a button press, including temperature in K, C, F, and system state.
 Allow all aspects of the system to be configured using variables.
    balearicdynamics over 8 years ago in reply to clem57 +6
    Sounds like another final exam task
    mcb1 over 8 years ago in reply to balearicdynamics +6 suggested
    looks that way
  • clem57
    clem57 over 8 years ago +2 suggested
    Show me the wiring of the hardware with a Fritz model and I can get you started.
  • clem57
    0 clem57 over 8 years ago
    0 balearicdynamics over 8 years ago in reply to clem57
    Sounds like another final exam task image
    • Vote Up +6 Vote Down
    0 mcb1 over 8 years ago in reply to balearicdynamics
    looks that way
