Robotics
Robotics
Forum How To Make Autonomous Following Drone
  • Replies 23 replies
  • Answers 11 answers
  • Subscribers 64 subscribers
  • Views 4989 views
kankurcool
kankurcool over 8 years ago
Hello... I'm Ankur, Studing IT Engineering in INDIA .
I want to make a Drone / Quadcopter That Recognize me And Follow me Around....
I Also  Want to Add Movements to dorne  Performed by My Hand Gestures...
I have Heard of Raspberry Pi And arduino...
Which will be Suitable For This Project among Both?
Will it Work Good If i use OPENCV For Person or Object Tracking....?
Will OpenCv Work in RealTime With Raspberry Pi or Arduino Uno...
What Programming Language  I Should Know?
How do i Start from scratch?
What Are The Equipment i will be needing InThis Project..?
Reply ASAP!
Please!  GUIDE  Me i came with lots Of hope...
Thank You..
ANKUR KUMAR
My Email : kankurcool@gmail.com
    Jan Cumps over 8 years ago +4 suggested
    The first commercial company that tried this (and didn't deliver anything), Lily Drones, went bankrupt with many milions of money from preorders and even more milions from angel investors, in their pocket…
    jw0752 over 8 years ago +3 suggested
    Hi Ankur, The functions that you are looking for are very complex and if possible are surely on the border of what is technically possible at this time. I do not want to discourage you but the only way…
  • beacon_dave
    beacon_dave over 8 years ago in reply to DAB +3
    That would be located here: Episode 38: See Ben Build an Autonomous Robot Luggage! (I've seen quite a few copies of this project posted on the web since.) Ben's 'auto tracking camera' episode may be of…
  • kankurcool
    0 kankurcool over 8 years ago
    Thank You Everyone..
    Here is Something I found Which Is Similar To My Topic
    The astounding athletic power of quadcopters - Raffaello D'Andrea
    https://youtu.be/w2itwFJCgFQ
    BTW  IDK Much about Arduino...
    But I Deeply Want to learn it... I want Make Something.. So Which one Will Suit My learning about
  • kankurcool
  • beacon_dave
    0 beacon_dave over 8 years ago in reply to kankurcool
    If you want to learn about Arduino basics then try starting here:
    Jeremy Blum Arduino Tutorials
    If you want to learn about AVR (the technology behind the early Arduinos) then try this course
    https://www.youtube.com/course?list=ECD7F7ED1F3505D8D5
    and take a look at some of the student projects form that course here:
    https://www.youtube.com/playlist?list=PLEB09A7C8641987A8
    Also perhaps take a look at the Atmel AVR introduction:
    https://www.youtube.com/playlist?list=PLtQdQmNK_0DRhBWYZ32BEILOykXLpJ8tP
  • kankurcool
    0 kankurcool over 8 years ago in reply to kankurcool
    Smart Gestures, Person Recognition...
    And Move Camera accordingly..
    Can Arduino + Pixy Cam can Work Together?
    Can I Use OpenCv.?  will it be Compatible..?
    Can I Program Them to Work Together.?
    For Now I Just want To Make camera Track Object in X-Y Axis.
    Which One Should I Order Arduino Or Raspberry Pi?
    This Is Going To Be My Final Decision .
    Thank You Again...
    0 balearicdynamics over 8 years ago in reply to kankurcool
    I enjoyed seeing it. You see, your idea is possible. So, go ahead image
    Enrico
    0 Jan Cumps over 8 years ago in reply to balearicdynamics
    I seem to be the odd one out on judging feasability.
    If you have the budget of the American Department of Defence, yes , there's a chance to deliver what you defined in the original post.
    Else: some semi-working toy.
    I'd like to see the original posters's end result and then talk to you again ...
  • beacon_dave
    Perhaps take a look at "Hooking up Pixy to a Microcontroller (like an Arduino)":¶
    http://cmucam.org/projects/cmucam5/wiki/Hooking_up_Pixy_to_a_Microcontroller_(like_an_Arduino)
    "Out of the box, Pixy is ready to talk to an Arduino. It sends block information to Arduino at 1 Mbits/second, which means Pixy can send more than 6000 detected objects per second or 135 detected objects per frame (Pixy can process 50 frames per second.)"
    Ben controls a camera slider with a Pixy plus an AVR dev board in this show which sounds similar to what you are trying to achieve initially:
    Episode 173: Ben Heck’s Auto Tracking Camera Part 1 Episode
    If you want to install OpenCV on the embedded device then you'll probably want to go down the Raspberry Pi route.
    The R-Pi can also use the Pixy module.
    Hooking up Pixy to a Raspberry Pi - CMUcam5 Pixy - CMUcam: Open Source Programmable Embedded Color Vision Sensors
    However Pixy and OpenCV are performing similar functions. You would likely use one or the other, not both. The Pixy has its own camera built-in whereas OpenCV requires an external camera such as a USB camera or R-Pi camera. So if you have to use an external camera (e.g. one built into a drone) then you would be looking at OpenCV rather than Pixy.
    You need to look at many aspects before deciding upon which platform to work with - power consumption and weight usually come into it if you are planning on attaching this equipment to the drone itself.
