Member's Forum 8-gang individually switched power strips hard to come by?
  • Replies 15 replies
  • Subscribers 566 subscribers
  • Views 1307 views
Andrew J
Andrew J over 6 years ago
Well so it would seem.  If I wanted a rectangular 4x4, individually switched, surge protected extension lead, no problem.  If I wanted a 8x1 surge protected extension lead, no problem.  But a 8x1, 3-metre, individually switched, surge protected extension lead seems to be non-existent.  Has anyone come across anything like this - perhaps has better Google-fu than me?  UK socket.
On eBay, 166BatteryWorld are selling a configurable tower with 4 gang-per-layer (or 2-gang + 2-usb socket layer) which might work: although only a layer (4 sockets) are switchable.  https://www.ebay.co.uk/itm/3M-Switched-Surge-Protected-Extension-Lead-UK-Plug-Tower-Multi-Socket-4-USB-Port-/32366697679…
I've not heard anything about them, they purport to ship from Portsmouth in 1 day yet are a Chinese company: we've all heard the horror stories about chinese-sourced power supplies when non-branded so I'd be a little concerned.  There are lots of sellers with the equivalent which doesn't help with confidence either.  Has anyone had any dealings with them?
Andrew
  • beacon_dave
    beacon_dave over 6 years ago in reply to Andrew J +4
    Here is a bespoke one they made for me some time ago. There's just never enough outlets these days...
  • beacon_dave
    The eBay one's look like they might do but, as I say, I've heard a fair few horror stories about non-branded Chinese power supplies so I'm a bit wary. Yes, be aware that a lot of those cheap deals on the…
  • beacon_dave
    beacon_dave over 6 years ago +3
    Perhaps speak to Olson... https://olsondirect.co.uk/8-way-13a-individually-switched-neon-fused-pdu.html?___SID=U they can do bespoke. Alternatively swap the plug for a surge protected plug-cap
  • 14rhb
    14rhb over 6 years ago
    I've found  6way switched with 2m lead from a reputable seller of quality items to the electrical trade:
    https://www.tlc-direct.co.uk/Products/TACS924N.html
    Rod
  • Andrew J
    Andrew J over 6 years ago in reply to 14rhb
    Yes, I can find lots of those.  What I need (want) though is 8 individually switched with a 3m cable that isn't in a 4x2 but a 8x1 layout.  Hen's teeth.  Something like: https://www.amazon.co.uk/Brennenstuhl-Premium-Line-extension-GERMANY-switch/dp/B00P142TPY/ref=pd_ybh_a_15?_encoding=UTF8…  but with each socket switched, although I could live with that for one of my purposes.  There is this: https://www.amazon.co.uk/dp/B00YCAGVOS/ref=psdc_1098227031_t4_B00P142TPY  which give 8 + 4 with each bank switched which is like Shabaz's suggestion above.
    Dave's pointer to Olsen looks ideal: 8 switchable with a separate earthing point with stud - I currently use a plug with stud.  The cost though....
    Andrew
  • Andrew J
    Andrew
