Feedback and Support
F&S Forum Help, my breadboard isn't working
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Sat, 20 Dec 2025 23:16:24 GMT ETag: "0x8DE317E31FF1C26" Set-Cookie: .te.csrf=VWPmgb-aVFlK66bdLPO8on-FgxHLrvTWdcKMddHONA4; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_YSnMJM2MOq5uBySmOTYtwzJymTRdmbmCnlJSBZbEAWfyTYS0ehrWTCkYLBH%2fLhlmmsiguVV0XyHKhDoaJkaxNu8aUMnTQ20KFjGyicInguOoHL3OxnKQqLaQgBY6ABfF7XQBbWivtEx9Xb0Zy8b6s1EUQEQ16n2IC2TXqReazwLuCQBV96oCh2dwoRWp4LhbLJsjDJ%2bdev66%2fJHJUO5aYb%2bsrX%2fRxrTbJ%2b64iVGvcx%2b8cowGixvXc3mKShOlbNFb4xsLJjxjlnJfCil56MhkrQ%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=26 Server-Timing: origin; dur=53 Server-Timing: ak_p; desc="1766272584837_34604952_298594174_7920_5327_7_8_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Locked Locked
  • Replies 22 replies
  • Subscribers 25 subscribers
  • Views 1195 views
  • Other
cstanton
cstanton over 6 years ago
I'm not sure what's wrong, I've plugged everything in. Maybe it needed more salt?
Though I suspect the power lines are broken because it's sliced.
  • luislabmo
    luislabmo over 6 years ago +10
    The problem is very obvious, you are using a counterfeit, by doing some google search I've found THIS is a breadboard Luis
  • jomoenginer
    jomoenginer over 6 years ago +9 verified
    Looks like you're in need of an Allevi Bioprinter. https://allevi3d.com/ https://www.sciencedirect.com/science/article/abs/pii/S0260877417300080
  • gecoz
    gecoz over 6 years ago +8 suggested
    You definitely need to use good quality solder paste!
  • beacon_dave
    beacon_dave over 6 years ago +5
    Looks like potential there for your circuit being 'toasted'...
  • beacon_dave
    beacon_dave over 6 years ago in reply to beacon_dave +5
    Kramer were using potatoes this year at ISE 2019 - so I guess that their circuits had a potential of being 'baked'...
  • Dudley
    Dudley over 6 years ago in reply to beacon_dave +5
    but if he toasted it too much the black smoke would escape?
  • 14rhb
    14rhb over 6 years ago +5
    Christopher, Ah, you've got a lead pop out (in the centre back) - always a problem with cheaper breadboards so I'm surprised to see it in your rye topped quality brand....maybe go for a nice Vollkornbrot…
    DAB over 6 years ago +5
    It is obvious, your circuit should be gluten free. DAB
  • phoenixcomm
    phoenixcomm over 6 years ago +4
    I think it got toasted!
  • cstanton
    cstanton over 6 years ago in reply to beacon_dave +3
    Perhaps I should consider the electrical conductivity of the spread on the toast? Attachments: community.element14.com/.../Flow_2D00_Transmitter_2D00_TE67A_5F00_investigated_2D00_products_2D00_conductivity…
    0 dougw over 6 years ago
    Unfortunately this type of breadboard is surface mount only, and you have to spread the conductive paste on and mount components before baking. image
    It  may also be feasible to create conductive carbon traces between components by burning with a fine tip iron. image
  • Gough Lui
    0 Gough Lui over 6 years ago in reply to dougw
    Yep, I see those crusty joints all over the board ...
    - Gough
  • Gough Lui
    - Gough
