I'm designing an open-source USB 3.x Type-C (KVM) Switch, and I'm looking for some feedback on the design I came up with.
The USB 3.x Type-C (KVM) Switch will be the modern version of a traditional KVM Switch, meant to work with modern USB Type-C capable monitors like the Dell P2720DC.
These monitors can use a single USB Type-C cable to carry a high resolution video signal, USB data signals and are also capable of charging connected devices using USB Power Delivery.
Usually there is just a single USB Type-C input available, and as I have multiple devices I started looking for USB Type-C switches. It turned out there are not too many options available, and all are like super expensive ($100+). So, I decided to try to design one.
The device will have the following features:
- two USB 3.x Type-C Input ports
- one USB 3.x Type-C Output port
- switching of all four USB 3.x SuperSpeed differential pairs
- switching of the USB 2.x HighSpeed differential pair
- switching of the Configuration (CC) and Sideband use (SBU) channels
- USB Power Delivery pass-through up to the full power range 20V @ 5A
- reasonable cost
In terms of design, I think we should have the following sections:
- USB 3.x SuperSpeed differential pair switching
- with high bandwidth (5-10 GHz) analog multiplexers / de-multiplexers designed for differential signals
- best candidates are Texas Instruments HD3SS3212, or ON Semi FUSB340TMX
- biasing on the differential lines may be needed
- USB 2.x HighSpeed differential switching
- can be done using IC-s designed for USB 2.0 switching
- there are lot of options, ex. Texas Instruments TS3USB221 - I will probably choose one based on price and availability
- switching of auxiliary Configuration (CC) and Sideband use (SBU) signals
- these are supposed to be low speed and voltage signals
- can be switched with any analog multiplexers / de-multiplexers, ex. Texas Instruments TS3A44159
- switching of the VBus power signal
- this is trickier as with USB Power Delivery the voltage can go up to 20V @ 5A, and the power can be provided either by the input or output port
- can be done using high power photocouplers, like the Toshiba TLP3547
- the disadvantage is that this high power photocouplers are super expensive - probably it can be done easier and I'm just over-complicating it (?)
- 3.3V power supply
- combine the VBus signal of the three USB Type-C connectors with diodes
- use a LDO regulator to generate the 3.3V power rail
- Microcontroller and I/O
- something Arduino compatible, maybe an SMT32
- not yet included in the schematics
- control by a button, and feedback by one or more LED-s
Here is the first version of the schematic I came up with:
The PCB probably will be a 4-layer one. I also thought to try (just for fun) a 2-layer PCB with a shielding provided by an aluminium casing.
So, I wanted to ask what do you think about this design?
Do you see anything terrible wrong with it? What are the parts of the design that can be improved?
Attila
