Ask an Expert Forum Is it safe to connect linear voltage regulators in parallel to a common source?
  • Replies 15 replies
  • Answers 3 answers
  • Subscribers 307 subscribers
  • Views 2489 views
  • voltage regulator
  • power
  • linear regulator
See a helpful answer?
nc_circuit_surgeon
nc_circuit_surgeon over 9 years ago
I'm working on a linear power supply. 12VAC comes in, gets rectified, and charges my reservoir capacitor bank. I'd like to obtain both 12VDC and 5VDC, is it ok to connect the input pins of my 12V and 5V linear regulators to the same node (the same reservoir capacitor bank)? I'm attaching a sketch of the circuit in question for clarity.
  • Robert Peter Oakes
    Robert Peter Oakes over 9 years ago +2 suggested
    Agree with most of the comments and I think these days, a simple buck regulator for the 5V would be way more efficient but at the end of the day, if you only need 5V at 100mA and its not battery powered…
  • michaelwylie
    michaelwylie over 9 years ago +1 verified
    The way you have drawn it is the way it should be implemented. You don't want the 12 Volt supply to affect the 5V rail at all, that is, if the 12 Volt rail is damaged, you've just lost the 5 as well. As…
    jw0752 over 9 years ago +1 suggested
    Hi Stephen, I did a blog a while ago on the difference between the linear and the switched buck converters. If you don't check out anything else, check out the link at the end of the blog to Recon's Book…
  • D_Hersey
    0 D_Hersey over 9 years ago
    Do you plan to use an input transformer?  Seems so.  You need to run some formalisms.  The 12V regulator needs a little overhead.  You should sim in LTI spice.  Your 5V regulator will consume more power than its load.
  • nc_circuit_surgeon
    0 nc_circuit_surgeon over 9 years ago in reply to D_Hersey
    Yeah, 24VCT transformer. ~17V peaks going into the rectifiers and I specced everything after to provide at least 12.5V to the 12V LDO under worst case conditions (temperature & line fluctuation).
