Ask an Expert Forum How do you choose soldering iron tip size and solder wire diameter?
  • Replies 29 replies
  • Subscribers 319 subscribers
  • Views 9260 views
  • solder breadbox
See a helpful answer?
HKPhysicist
HKPhysicist over 1 year ago
Hello Friends and E/E Engineers,
I have bought this solder bread box for my new project.  This is my first time to solder my own circuit.
I think it is the universal standard 0.1" pitch holes board.
According to your precious experiences, what soldering iron tip size and soldering wire diameter do you choose?  Primarily, I do pass-though-hole parts plus few SMD. Pray
I did try a soldering iron tip in 1mm diameter and solder wire in 0.8mm diameter on this board but my solder joints seem too fat Penguin , not as slim as theirs shown here:
https://www.adafruit.com/product/5900
    shabaz over 1 year ago +5
    Names of some typical tip shapes to help with the terminology (since some of it may become lost in translation for non-English-language readers).
  • phoenixcomm
    phoenixcomm over 1 year ago +4 suggested
    HKPhysicist Ok FORGET EVERYTHING YOU KNOW, THINK YOU KNOW. Go to my Soldering School blogs and READ ALL POSTS! Then Download from the web NASA-STD-8739.3, NASA Training - Student Workbook for Hand…
    Jan Cumps over 1 year ago +3
    For this type of perfboard, the standard tip of most irons will do. I think that your joint quality is either due to: - wrong temperature - wrong technique - not enough flux Questions: - What…
  • acdc90
    0 acdc90 over 1 year ago
    Hello for the last 15 years i have been using the Hako 924 series iron
    at the start i was using the pencil tip then i found the Knife edge tip
    the main advantage i found with this tip was better control of heat
    then when working on industrial boards usually 3mm thick
    or with large ground plans i would ad a 2nd iron with knife tip.
    most of the time i am using 0.9mm 60/40 solder
    even when SMD ic's
    Using x10 or x15 glasses of course
    tried using different brands of 0.5mm solder but just not the same quality.
    Some good practice for a beginner is removing parts from different old boards
    then refitting them
    When I started working on down hole servey tools
    the manufactor has specified solder with silver content
    to keep up with the boards when they are down the hole in 130' C enviroment
    the next day i need to clean up my tip.
    if you want to challenge your soldering try doing Cheap plastic connectors
    Hint put the plug into the socket then solder the plug pins.
    only the good will try wiring a lemo FFG.0B  7 pin plug with heat shrink on 0.5mm core
  • acdc90
    even when SMD ic's
    then refitting them
