element14's The Ben Heck Show
Forum Stepper Motor Troubleshooting
  • Replies 44 replies
  • Subscribers 33 subscribers
  • Views 5645 views
  • help
  • 3d
  • me
  • tags
  • stepper
  • stuff
  • help!
  • printing
  • motor
  • heck
  • ben
fuzion_reaktor
fuzion_reaktor over 11 years ago
Hello, my name is Peter R and for the past several months I have been building a 3D printer. I have the frame and everything done, but I consistently run into the issue where my stepper motors run erratically; when I issue a movement command they change direction at random, move in unpredictable spurts, clank, grind and make weird noises--and that's if I'm lucky enough to get them running at all. They appear to be uni-polar motors, and I have wired their four wires in as many orientations as possible and still get the same issue? Is this a board problem, or the motors themselves?
The motors are 17H249-02S motors, manufactured by Xuquan motor, but there is little documentation on them on the internet as far I have found.
Many thank to whoever can answer this.
  • fuzion_reaktor
    fuzion_reaktor over 11 years ago in reply to D_Hersey +2
    Huzzah (yes I say huzzah) I have inadvertently solved my problem. My end-stops were wired improperly so the control board thought that they were closed. Thus my motors could never move in the direction…
  • fuzion_reaktor
    fuzion_reaktor over 11 years ago in reply to kidiccurus +1
    Motors, yes are a plugging in problem. This is just weird. But switching the two works and I have successfully printed a small misshaped cube...Progress...
  • D_Hersey
    0 D_Hersey over 11 years ago
    This is what you are going for.  Notice how only one coil changes per step, reminiscent of Grey codes.  Going backwards means going -1 step.
  • fuzion_reaktor
    0 fuzion_reaktor over 11 years ago in reply to D_Hersey
    Great. Now, how do I get it to run backwards as well? BTW I'm using Repieter Host's manual control function to run the motors.
  • fuzion_reaktor
