Sensors
Sensors
Sensor Forum Understanding the differences between Gyroscopes and Accelerometers
  • Replies 21 replies
  • Answers 5 answers
  • Subscribers 344 subscribers
  • Views 4777 views
Hello all,
I apologize for what is likely an ignorant question, but I am fairly new to electronics and have little confidence. I am working on a personal project where I am using a servo motor to move a rod back forth 90 degrees (not exactly, but this analogy should suffice), and I am interested in measuring the instantaneous (angular?) acceleration (I want to use it to calculate torque). Surprisingly, I have come across trouble while researching online for a sensor to do this. My understanding now is that an accelerometer is only capable of measuring linear acceleration (which means the object can't be rotating, right?), while a gyroscope only measures angular velocity when an object is spinning about an axis. Technically, the rod in my project isn't spinning-it's just rotating back and forth between two angles (0 and 90) on the XY plane. Is there a simply way/sensor to do this? More broadly, am I completely misunderstanding the uses of gyroscopes and accelerometers? I hope i explained the issue properly...
  • amgalbu
    amgalbu over 11 years ago in reply to Former Member +1
    Accelerometer measure acceleration. According to physics , acceleration is a variation in speed. If an object is falling, its speed increases of 9.8 m/s every second, so its acceleration is 9.8 m/s^2 usually…
  • D_Hersey
    0 D_Hersey over 11 years ago
    I don't know your precision requirements.  You can fab a cheap rotary encoder from a stepper motor and a quadrature detector.
  • D_Hersey
