element14's The Ben Heck Show
Forum Tesla coil music player
  • Subscribers 30 subscribers
  • Views 455 views
I need too figure out how to take a standard audio jack output and convert it into pluses of varying frequency
within the range of audible human hearing for example input comes in at
1.2 volts its pules at 3,000 hertz
1.3 volts its pules at 3,500 hertz
1.4 volts its pules at 4,000 hertz
1.5 volts its pules at 4,500 hertz
I have very limited knowledge with such things and i need help with this project of mine image
  • 4ringfan
    4ringfan over 10 years ago +3 suggested
    I'm not going to answer your question directly, but I will hopefully point you in the right direction. Check out this website: DIY Tesla Coil Kit Downloads http://onetesla.com/oneTesla_User_Manual.pdf…
  • 4ringfan
    0 4ringfan over 10 years ago
    I believe that you are looking at an interrupter?
    https://www.youtube.com/watch?v=7q2mRUKPGZU
    -4RINGFAN
  • 4ringfan
    -4RINGFAN
    0 Former Member over 10 years ago in reply to 4ringfan
    Okay i have found an interrupter board that will out put a fiber optic signal but i need something on the other end that can handle the output Voltage  from the several KV transformer and regulate its flow to the actual Tesla coil transformer
