      • Japan
      • Vietnam
Twist, Turn and Move Design Challenge with TE Robotics
  • Twist, Turn and Move Design Challenge with TE Robotics
Documents The Twist, Turn, and Move Robotics Design Challenge with TE Connectivity
  • Author Author: e14phil
  • Date Created: 28 Apr 2022 2:41 PM Date Created
  • Last Updated Last Updated: 28 Sep 2022 2:36 PM
  • Views 17930 views
  • Likes 13 likes
  • Comments 51 comments
Make that machine move using TE Connectivity!
design challenge profile
The Twist, Turn, and Move Robotics Challenge
About This Challenge | Dates | The Judges | The Kit | The Prizes | Example Application | Terms & Conditions | The Challengers
The Challenge
Each participant will receive a Challenger’s Kit, with which they are challenged to design and build a robotic arm or mobile robot that performs a specific task.
10 successful applicants will get a Selection of TE Connectors, an Arduino Uno, and Robotics Shields, free of charge, to build and blog their project with.
For the chance to win one of the prizes below, participants must blog their build process, as well as the final outcome of their Robotic Movement Project.
Included in the Challenger's Kit are a Selection of TE-provided components, as well as an Arduino Uno; use these to create your Robotic Movement Project.
Good integration of the TE components and interesting uses of movement will be graded more favorably.
Example tasks that can be performed include, but are not limited to:
  • Building a robot arm that can pick up and set down an object
  • Building a robot arm that moves in all degrees of freedom
  • Building a mobile robot that follows a line
  • Building a mobile robot that can avoid an object in its path
Challenger's Kit The Kit Product Name
connectors kit
TE Connectors Kit
(Product Image may differ)
Dynamic Connectors Parts:
1-2366515-4 Connector Housing
2367817-2 Contact
2-2366515-4 Connector Housing
1-2366600-4 Connector Housing
2367819-2 Contact
2-2366600-4 Connector Housing
1891526-1 Extraction Tool
1-2366515-8 Connector Housing
2-2366515-8 Connector Housing
1-2366600-8 Connector Housing
2-2366600-8 Connector Housing
More Items:
AXICOM IM Signal Relay
M4473 SL005 Multipair Cable
Circular Plastic Connector Series 1
Circular Connector Size 11
M8 Series Connector Male
M8 Series Connector Female
D-Sub Connector
D-Sub Connector
201328-1 Multimate Contact Type II
201330-1 Contact
Wired-Board Connector
Receptacle FFC/FPC Connector
Pin Header
connectors kit
Arduino Uno
Buy Now
connectors kit
DRI0017 2x2A Motor Shield for Arduino Twin (Product Image may differ)
connectors kit
DFR0502 Gravity: IO Expansion & Motor Driver Shield (Product Image may differ)
The Prizes
Prize Prize Category
Grand Prize
Approximate Value $2100 USD*
  • Flash Forge Guider II 3D Printer
  • iRobot Roomba Self Emptying Robot Vacuum Clearer
Runner Up
Approximate Value $500 USD*
  • iRobot Bravaa Jet Robot Mop
  • Ender 3 V2 3D Printer
Finisher Prize**
To be a finisher you must complete 5 blogs and show us your testing the resilience of the project.
Approximate Value $30 USD*
  • Multicomp Pro Multimeter
*Or local equivalent
**Grand Prize and Runner Up winners also earn the finisher prize.
The Judges
element14 Community Judges
element14 Community Team
The Dates
The Dates
To make sure challengers get their kit on time we have pushed back the end dates of this challenge and will be updating the site copy and terms to correspond with this.
Project Phases Dates
Challengers Announced 6th July 2022
Build Period 7th July - 12th September 2022
Projects Due 12nd September 2022
Winners Announced October 2022
Prizes Shipped October 2022
The Terms
Selected official applicants will be chosen to receive the "Kit" listed above; these successful applicants will be our sponsored challengers. The sponsored challengers must use the Challenger's Kit within their project, and publish their final code and designs on the Community for others to use. Those not chosen as sponsored challengers may also join the competition and be eligible to win prizes, but they must base their projects around the Challenger's Kit (which they will obtain themselves) and adhere to all terms and conditions of the challenge.
Applicants must post their progress and final project as at least 5 blog posts before the closing date (see above), when projects are due. Challengers are strongly encouraged to post their blogs regularly during the contest period, rather than posting them all close to the finish of the competition; judges will look more favorably on those who blog regularly during the contest period.
Projects that use the Challenger's Kit most creatively, along with posts that are media rich with photos, videos, and code samples will be viewed more favorably in the judging process.
Please read the full terms and conditions of the challenge, attached below.
Ready to join the challenge? Then apply here!
If you are not successful in becoming a sponsored challenger, but still want to enter, all you need to do is use at least 5 of the TE connectivity products described above, as well as the Arduino UNO, in your project and adhere to the same Terms and Conditions for a chance to be our winner! Non-sponsored challengers are eligible for the Finisher and Winner Prizes, as well.
  • turn
  • twist
  • te connectivity
  • robotics design challenge
  • and move design challenge
    Jan Cumps over 3 years ago in reply to guillengap +3
    Who's going to want to volunteer for judging in the future, when you seem to try and turn it into a liability instead of a community service? You're turning the disappointment for not winning the previous…
  • e14phil
    e14phil over 3 years ago in reply to guillengap +3
    Hey guillengap , Understood, I am happy to remove from the list, you will not be contacted as a challenger. Even if the current state of Design Challenges do not gel well with your expectation, we will…
  • rscasny
    rscasny over 3 years ago +2
    We updated the parts list for the kit. For the connectors, you should be getting plug, socket and contact pins for each. Randall
  • robogary
    robogary over 3 years ago in reply to Jan Cumps
    Waa able to get back on this website after a couple more Gateway timeouts, and found the earlier blog I worked on did not save as a draft. Also got a message that I was disconnected and automatically reconnected. Cie la Vie
  • robogary
    Maybe isnt the website directly. A couple times I got this message. Gateway TimeoutThe proxy server did not receive a timely response from the upstream server.   The cloud gets nebulous somewhere in its travels. Maybe a backup server is running Windows ME and cant keep up when called upon for duty :-)
    Jan Cumps over 3 years ago in reply to robogary
    Yes. This seems to repeat every weekend.
    Each community staff member should mandatory have to write a blog every Saturday and Sunday. So that they see what the community experiences in the weekends.
  • robogary
    Anyone having issues blogging ? The website is buffering so bad I couldnt even leave a comment on the feedback and support area. I couldnt get photos and jpgs to upload reliably, or even save a draft. After waiting 15-30 minutes, the site would eventually flag an error occurred, please try again.
  • robogary
    robogary over 3 years ago in reply to rscasny
    Thank you so much for the needed D-1000  pins & sockets, they were delivered today just in time to start the system interconnects & integration.  Your quick help is appreciated.
  • a33333
    a33333 over 3 years ago in reply to rscasny
    Hi Randall,
    It would be great if I could get some extra 24 sets of pins and sockets for the D-1000 connectors. (part no 2367817-2 and 2367819-2).
    Many thanks.
    dougw over 3 years ago in reply to rscasny
    The kit included two 8-pin headers:
    6-104074-0
    6-104071-0
    There was one mating housing, but it did not have any receptacle contacts. I think that particular housing takes some contacts that splice into flex cable - probably requiring special tooling. The  A9CCA-0806E part is a cable with receptacle contacts already assembled. It is not easy to find.
    It looks like this:image
    An alternative would be to supply the two PCB mount receptacles which I think can probably mate with the two headers:
    7-104196-1    https://www.te.com/usa-en/product-7-104196-1.html
    7-104192-1    https://www.te.com/usa-en/product-7-104192-1.html
  • robogary
    Thank you Randall , you are awesome.
  • rscasny
    rscasny over 3 years ago in reply to dougw
    I can order the contact. But I'm having a problem locating the A9CCA-806E. Where did you get that p/n?
    Randall
  • rscasny
    rscasny over 3 years ago in reply to robogary
    I'm ordering these today.
