1 Meter of Pi
  • 1 Meter of Pi
1 Meter of Pi
Blog 1 METRE OF PI – FIFTH POST – REVERSE ENGINEERING PROCESS PART 2
  • Author Author: stevotech
  • Date Created: 14 Nov 2020 10:22 AM Date Created
  • Views 523 views
stevotech
stevotech
14 Nov 2020
How are the most important areas of control to be included in the modular vertical farm construction to create the right Environment and provide climate control?
Probably the most important areas of control within the main structure are:
Lighting, Temperature, Humidity, Water/Moisture
This will apply to all levels and assuming that individual containers or trays could be included in the overall design, then two areas of control are likely to be:
Temperature of the plant/food and Water/Moisture Content
Within the structure sensors will require to be fitted in four locations, L, T, H & W
Plus, T & W for containers
See jpeg, ‘Ref 6001 Environment’
Another aspect to be catered for - and shown in the jpeg - is Services and fitting-out to provide for Electrical Power & Control lines, Water pipes and Air pipes
1meterofpi raspberry_pi, design challenge, raspberry pi 4 2gb, 1 meter of pi, 1_meter_of_pi, 1 meter of pi - design challenge
